LWIP Client
I have a LWIP client. recv() is done is a separate task. When I want to close the socket from another task I get an error:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Assertion "OSQDel " failed at line 93 in /cygdrive/c
/altera/kits/nios2_60/components/altera_lwip/UCOSII/src/downloads/lwip4ucosii/uc
os-ii/sys_arch.c[/b]
--- Quote End ---
This probably because the recv mailbox cannot be deleted because the receive task is pending on it.
Calling the recv() function only after a select() so the recv() does not block does not help, the mailbox cannot be deleted.
How can I close a socket form a task while another task is receiving on it?
