12748 Discussions
LXDE apt-get fails 404 Error
I am using the LXDE image from the terasic website. When I do apt-get update, it fails with 404 errors. It is not a connectivity issue (I can connect to the internet). I believe it to be a problem in the /etc/apt/sources.list file, which currently contains:
deb http://ports.ubuntu.com/ubuntu-ports/ quantal main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ quantal main universe
The error I get is:
Err http://ports.ubuntu.com quantal/main Sources 404 Not Found
Err http://ports.ubuntu.com quantal/universe 404 Not Found
Err http://ports.ubuntu.com quantal/main armhf Packages 404 Not Found
etc...
Is there a way to fix this so that apt-get actually functions?
Mike
<edit>
optional: set date:
ntpdate pool.ntp.org
</edit>
vi /etc/apt/sources.list
Change contents to:-
deb http://old-releases.ubuntu.com/ubuntu/ quantal main universe
deb-src http://old-releases.ubuntu.com/ubuntu/ quantal main universe
After some further digging around I managed to fix this problem properly:-
Delete all lists of downloaded packages:-
cd /var/lib/apt/lists rm *
Update package lists:-
apt-get update
Upgrade:-
apt-get upgrade
Probably libssl1.0.0 will be upgraded from 1.0.1c-3ubuntu2.5~linaro1 to 1.0.1c-3ubuntu2.5~linaro2
Optional, Install SSH & change passwd:
apt-get install openssh-server passwd
