Linker error with BSD sockets
I am a definite newbie to Nios/uClinux but not a newbie to UNIX development in general. I have a "server" program that I developed and tested using cygwin for Windows, and now am trying to port over to Nios. I get linker errors like the sort shown below:
gc102.o(.text+0x94):/cygdrive/c/Altera/src/gc102/gc102.c:173: undefined reference to `gethostname'
gc102.o(.text+0x9c):/cygdrive/c/Altera/src/gc102/gc102.c:174: undefined reference to `gethostbyname'
gc102.o(.text+0xcc):/cygdrive/c/Altera/src/gc102/gc102.c:186: undefined reference to `bind'
gc102.o(.text+0xe4):/cygdrive/c/Altera/src/gc102/gc102.c:192: undefined reference to `listen'
gc102.o(.text+0x11c):/cygdrive/c/Altera/src/gc102/gc102.c:199: undefined reference to `accept'
gc102.o(.text+0x370):/cygdrive/c/Altera/src/gc102/gc102.c:97: undefined reference to `stderr'
The stderr one is a different issue, although I would like to solve the socket problem 1st since for the time being I can replace fprintf(stderr,"...') with printf() calls.
I tried linking in the standard libsocket.a library by adding -lsocket, but then I get an error that the cross-compiler/linker is unable to locate the sockets library:
/cygdrive/c/Altera/kits/nios2_51/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld: cannot find -lsocket
By adding the -v (verbose) flag to the linker I determined that with my installation, the libs are in C:\Altera\kits\nios2_51\bin\nios2-gnutools\H-i686-pc-cygwin\nios2-elf\lib. When I go to that directory I see many familiar static libraries, like libm.a, libc.a, and so on, but no libsocket.a. What am I missing here? Or is there a different library I need to be linking to/
Any help would be most appreciated.
Hi squreshi,
Welcome.
You need to link with libc for Nios II uClinux.
There is a Nios Wiki now, http://nioswiki.jot.com/wikihome (http://nioswiki.jot.com/wikihome) .
You can work on Linux. There is a Nios II cross compiler built with uClibc for uClinux.
You can install binary toolchain, http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain) .
Use uClinux-dsit to build your kernel,
http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist
And compile your app,
http://nioswiki.jot.com/wikihome/operating...ms/compilehello (http://nioswiki.jot.com/wikihome/operatingsystems/compilehello)
Thanks for the tip, that worked out for me. At first I was confused because the linker was already pulling in libc.a, just not the right libc.a. I had to update my link line as so:
nios2-elf-gcc -o <some executable> {object files} -v -l/cygdrive/c/altera/kits/nios2_51/bin/eclipse/plugins/com.microtronix.nios2linux.uclibc_1.4.0/lib -lc
When I search for all the libc.a files under the nios2_51, I end up with many different copies, presumably for different configurations. Is there a document somewhere that describes the differences between ...\nios2_51\bin\nios2-gnutools\H-i686-pc-cygwin\nios2-elf\lib\mhw-mulx, ...\nios2_51\bin\nios2-gnutools\H-i686-pc-cygwin\nios2-elf\lib\mno-hw-mul, and so on?
Thx,
-SQ
--- Quote Start ---
originally posted by hippo@May 24 2006, 10:21 PM
hi squreshi,
welcome.
you need to link with libc for nios ii uclinux.
there is a nios wiki now, http://nioswiki.jot.com/wikihome (http://nioswiki.jot.com/wikihome) .
you can work on linux. there is a nios ii cross compiler built with uclibc for uclinux.
you can install binary toolchain, http://nioswiki.jot.com/wikihome/operating...binarytoolchain (http://nioswiki.jot.com/wikihome/operatingsystems/binarytoolchain) .
use uclinux-dsit to build your kernel,
and compile your app,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15566)
--- quote end ---
--- Quote End ---
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
When I search for all the libc.a files under the nios2_51, I end up with many different copies, presumably for different configurations. Is there a document somewhere that describes the differences between ...\nios2_51\bin\nios2-gnutools\H-i686-pc-cygwin\nios2-elf\lib\mhw-mulx, ...\nios2_51\bin\nios2-gnutools\H-i686-pc-cygwin\nios2-elf\lib\mno-hw-mul, and so on?[/b]
--- Quote End ---
They are libs for different compiler option, ie multilib.
eg, with/out hw mul, mulx , etc.
You can find gnu tools doc in the nios2 dir.
