12748 Discussions
Linux with MMU hangs at 'RPC'
Built with the '20100621' . The board is DE2. 'make' is successful, and I've got the images.
After 'nios2-termina', it goes:
Linux version 2.6.35-00743-ge3b9b64-dirty (root@ubuntu) (gcc version 4.1.2)# 10 Wed Feb 2 17:18:05 CST 2011
bootconsole [early0] enabled
early_console initialized at 0xe1801230
Linux/Nios II-MMU
init_bootmem_node(?,0xd36, 0x800, 0x1000)
free_bootmem(0xd36000, 0x2ca000)
reserve_bootmem(0xd36000, 0x100)
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 2032
Kernel command line:
PID hash table entries: 32 (order: -5, 128 bytes)
Dentry cache hash table entries: 1024 (order: 0, 4096 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
We have 4096 pages of RAM
Memory available: 2772k/5335k RAM, 0k/0k ROM (2010k kernel code, 3324k data)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:32
Calibrating delay loop... 20.94 BogoMIPS (lpj=104704)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
NET: Registered protocol family 16
init_BSP(): registering device resources
bio: create slab <bio-0> at 0
Switching to clocksource timer
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
(Forever hangs here)
Being newbie to uClinux, dunno what to do.. Any ideas? Thank you!
Very nice project,
but where you find the Hardware Projetc ( .qar) for DE2?
I can help you with LINUX, but I need the Hardware.
Could you help?
Hi, I build the DE2 project myself with MMU.
The configuration of NIOS2 CPU with MMU is here:
http://www.alterawiki.com/wiki/creating_a_nios_ii_design_with_an_mmu
It is built with SOPC and the components includes:
1. niosii cpu
2. on-chip RAM
3. SDRAM
4. DM9000A
5. JTAG-UART
That's all, quite simple. But still hangs there after the 'RPC' statement :(
Nice,
today I'll try to build that HW.
RPC is a network problem, I guess. Today I'll ask a friend about your problem
Thanks for the HW tip
That's quite simple :D There exists many guidances on Altera wiki.
Yes, there is a lot of guidance on Alterawiki but none of them are specific for DE2 with MMU.
So, as I told you today, I'll try to build myself the HW project (for DE2) and after that I'll post it for the community evaluation.
