12748 Discussions
Little help with DMA reading from a source
Hello i have a fifo that get's filled after 10 seconds and i want to read half of the fifo from my DMA. How can i do that?
I am recieving a half_full signal from my fifo, which generates an IRQ.
I am getting this IRQ without any problem but i want to know how to tell the DMA to read 32 positions of my fifo (half).
My DMA CODE that works from SDRAM to ONCHIP ram is the follow
#include <stdio.h># include <unistd.h> // usleep()# include "system.h"# include "sys/alt_irq.h"# include "altera_avalon_pio_regs.h"# include <stdlib.h># include <stddef.h># include <string.h># include <io.h># include <alt_types.h># include "sys/alt_dma.h"# include "sys/alt_cache.h"# include "sys/alt_alarm.h"# include "sys/alt_irq.h"# include "alt_types.h"# include "altera_avalon_pio_regs.h" static volatile int txrx_done = 0; int i; static void handle_button_interrupts(void* context, alt_u32 id); volatile alt_u8 led=0; /* A variable to hold the value of the button pio edge capture register. */ volatile int edge_capture; volatile int irq_count; //callback function when DMA transfer done static void txrxDone(void * handle, void * data) { txrx_done = 1; } void initMEM(int base_addr,int len) { for ( i=0;i<len;i++) { IOWR_8DIRECT(base_addr,i,i); } } int initdma(void) { printf("testing fifo & onchip : dma operation\n"); alt_16 buffer; //memset((void *)SSRAM_0_BASE,0x7a,0x10);//this write base on byte //initMEM(FIFO_0_BASE,0x10); memset((void *)(DESTINO_BASE),0x33,0x10); printf("content of fifo:before DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(FIFOWRAPPER_0_BASE,i)); } printf("content of onchip:before DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(DESTINO_BASE,i)); } int rc; //request alt_dma_txchan txchan; alt_dma_rxchan rxchan; void* tx_data = (void*)FIFOWRAPPER_0_BASE; /* pointer to data to send */ void* rx_buffer = (void*)(DESTINO_BASE); /* pointer to rx buffer */ /* Create the transmit channel */ if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open transmit channel\n"); exit (1); } /* Create the receive channel */ if ((rxchan = alt_dma_rxchan_open("/dev/dma_0")) == NULL) { printf ("Failed to open receive channel\n"); exit (1); } /* Post the transmit request */ if ((rc = alt_dma_txchan_send (txchan, tx_data, 0x10, NULL, NULL)) < 0) { printf ("Failed to post transmit request, reason = %i\n", rc); //exit (1); } /* Post the receive request */ if ((rc = alt_dma_rxchan_prepare (rxchan, rx_buffer, 0x10, txrxDone, NULL)) < 0) { printf ("Failed to post read request, reason = %i\n", rc); //exit (1); } /* wait for transfer to complete */ while (!txrx_done); printf ("Transfer successful!\n"); printf("content of fifo:after DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(FIFOWRAPPER_0_BASE,i)); } printf("content of onchip:after DMA operation\n"); for ( i=0;i<0x10;i++) { printf("%d: %x\n",i,IORD_8DIRECT(DESTINO_BASE,i)); } return 0; }
Simply change to 32 the DMA length (which is now 0x10 in your example)
Then, you probably want the tx channel to get data from a constant address, since usually FIFOs work this way;
so, you need to set the RCON bit in the DMA control register (this applies to the standard Altera DMA core; in other cores there will be a similar control bit).
Hello Cris72, i see that the rcon bit is the bit number 8, what would be the C code to set it? I can't find in the literature..
nvm you've answered me this before
#include "altera_avalon_dma_regs.h" int reg; reg = IORD_ALTERA_AVALON_DMA_CONTROL (dma_base_address); IOWR_ALTERA_AVALON_DMA_CONTROL (dma_base_address, reg | ALTERA_AVALON_DMA_CONTROL_RCON_MSK);
