Loading of code to SRAM
Hello all,
In the system library properties I can ask for my code to run from the SRAM. I'm interested in knowing what happens behind the scenes when I compile and Run / Debug my code using the Nios IDE.
Is some loader created, prepended to my code and copies it into SRAM, jumping to it for execution ? What is going on exactly ? Can I see this loader / is this some assembly program ?
The same goes for a "production board" where the Stratix is loaded from the EPCS device. How is the code copied to SRAM ? Should I write a boot loader for that, or are there custom loaders available for this purpose ?
Thanks in advance
I remember that altera give a file to describle boot from flash.
We can select auto boot from flash to sram.
Yes, what you describe is what happens. The build process adds a boot loader that's responsible for copying the segments to the correct memory locations and then jumping to that location. There's a boot loader specifically for the EPCS.
You can look at the code of the bootloader(s) in your components directory, on my machine in c:\altera\kits\nios2_51\components\altera_nios2\sdk\src\boot_loader_sources)
Andrew
--- Quote Start ---
originally posted by queisser@Mar 15 2006, 02:31 PM
yes, what you describe is what happens. the build process adds a boot loader that's responsible for copying the segments to the correct memory locations and then jumping to that location. there's a boot loader specifically for the epcs.
you can look at the code of the bootloader(s) in your components directory, on my machine in c:\altera\kits\nios2_51\components\altera_nios2\sdk\src\boot_loader_sources)
andrew
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13482)
--- quote end ---
--- Quote End ---
Thank you, I will look at that.
For run/debug in the IDE (not flash bootload, as previously discused), the nios2-download app is called from the IDE. nios2-download communicates to the Nios debug core (thus necessitating the presense of one in your design) via your JTAG download cable. On the Nios side of things, the processor receives a special break signal that casues it to execute code from a small monitor inside the debug core. This monitor accepts commands from your PC (nios2-download) to read/write/verify memory as required to download and debug your application.
