Loading ucLinux on DE2
I am trying to load ucLinux on DE2. I compiled the kernel without ATA/ATAPI/MFM/RLL and networking support.
But i could not find the option to set Link address offset for booting as specified in post.
http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Processor type and features-->(0x00500000) Link address offset for booting[/b]
--- Quote End ---
I used Nios-II IDE to compile the kernel. I thought it would create problems only while booting the Kernel so proceeded with compilation. Kernel compiled succesfully. It created two files. vmlinux and vmlinux.bin. I thought vmlinux.bin is compressed version of vmlinux. vmlinux is 8.4MB and vmlinux.bin is 1MB.
I used following command to download linux:
nios2_download -g vmlinux.bin
and i get following error:
./vmlinux.bin File format not recognized.
I tried using gzip on vmlinux and uploading vmlinux.gz there also i get the same error.
One more problem is I am not sure if the kernel is being downloaded to flash or sdram. How can I specify that kernel should be loaded to sdram? should i do it in SOPC builder?
mythri,
I load the De2 board with following commands.
1. Bin -> Flash
bin2flash --input=vmlinux.bin --output=vmlinux.flash --location=0x0
2. Erase Flash
nios2-flash-programmer --debug --erase=0x0+0x200000 --base=0x2000000
3. Load Linux
nios2-flash-programmer --base=0x2000000 --debug vmlinux.flash
The Reset Address needs to be specified in SOPC builder
The base Address depends on your settings in SOPC builder
