12747 Discussions
Problem with bringing up Network
when trying to add network support to my board, i suffer at the following problem. After starting uCLinux, i configure the smc91111 on eth0 with ifconfig. all seems to work fine, but the network interface still does not work. Normally one of the ethernet leds should begin to blink, because it receives some packets from network, but it doesn't, but it should of course. I also tried ifconfig eth0 up. Both leds only flash once shortly after using ifconfig... nothing more.
I'm using a custom board. Before, working with uC/OS everthing works fine with the network adapter.
Here is my boot log:
Uncompressing Linux... Ok, booting the kernel. Linux version 2.6.16-uc0 (marekp@dryade26.ifh.de) (gcc version 3.4.6)# 19 PREEMP T Mon Sep 4 09:54:53 CEST 2006 uClinux/Nios II Altera Nios II support (C) 2004 Microtronix Datacom Ltd. setup_arch: No persistant network settings signature at 00FF0000 Built 1 zonelists Kernel command line: PID hash table entries: 512 (order: 9, 8192 bytes) Dentry cache hash table entries: 16384 (order: 4, 65536 bytes) Inode-cache hash table entries: 8192 (order: 3, 32768 bytes) Memory available: 63292k/65536k RAM, 0k/0k ROM (1179k kernel code, 363k data) Mount-cache hash table entries: 512 NET: Registered protocol family 16 io scheduler noop registered io scheduler deadline registered (default) Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x810131c8 (irq = 1) is a jtag_uart smc_probe: 50000 Khz Nios SMSC LAN91C111 Driver (v2.1), (Linux Kernel 2.6) eth0: SMC91C11xFD(rev:1) at 0x81000300 IRQ:6 MEMSIZE:8192b NOWAIT:0 ADDR: 00:07: ed:00:00:00 smc_probe: 50000 Khz Nios NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 4096 (order: 2, 16384 bytes) TCP bind hash table entries: 4096 (order: 2, 16384 bytes) TCP: Hash tables configured (established 4096 bind 4096) TCP reno registered TCP bic registered NET: Registered protocol family 1 NET: Registered protocol family 17 Freeing unused kernel memory: 260k freed (0x4134000 - 0x4174000) Shell invoked to run file: /etc/rc Command: hostname uClinux Command: mount -t proc proc /proc Command: mount -t sysfs sysfs /sys Command: mount -t usbfs none /proc/bus/usb mount failed: No such file or directory Command: mkdir /var/tmp Command: mkdir /var/log Command: mkdir /var/run Command: mkdir /var/lock Command: mkdir /var/empty Command: ifconfig lo 127.0.0.1 Command: route add -net 127.0.0.0 netmask 255.0.0.0 lo Command: cat /etc/motd Welcome to          ____ _  _         /  __| ||_|    _   _| |  | | _ ____  _   _  _  _   | | | | |  | || |  _ \| | | |\ \/ /   | |_| | |__| || | | | | |_| |/       |  ___\____|_||_|_| |_|\____|\_/\_/   | |   |_| For further information check: http://www.uclinux.org/ Execution Finished, Exiting Sash command shell (version 1.1.1) /> ifconfig eth0 141.34.30.108 netmask 255.255.255.0 broadcast 141.34.30.255 eth0:PHY 10BaseT eth0:PHY Half Duplex />
any suggestions, please?
Marek
