Local variables debugging
Hallo,
I have problem with function's local variable debugging. I'm trying watch function's local variable values in nios2-debug and also nios2-elf-gdb. Both of deguggers doesn't work with this variable, which has -1 value for all debbugging time and I'm not able to stepping program. Btw this variable has not static address in memory.
Problem I mentioned is with 'irq_id' variable in example:
int function(const void* xxx)
int irq_id = 0; /* cycle index */
for (irq_id = 0; irq_id < 32; irq_id++) {
return (NO_ERROR);
When I tried to declare function&#39;s local variable &#39;irq_id&#39; as &#39;staic&#39;, debuggers works correctly, but I think that debuggers must work with &#39;auto&#39; declared function&#39;s local variables...
I&#39;m using GNU based development tools only, not NiosII IDE.
Thank you for some motive.
