12618 Discussions
LwIP doens't work with NIOS II 6.0
Hi all,
I&#39;ve a Standalone LwIP project (download from topic "Tested IP") with NIOS II & QUARTUS 5.1. I&#39;ve been testing this project with NIOS II & QUARTUS 6.0 and i&#39;ve got a lot of problems and I couldn&#39;t build my project. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
It&#39;s related with LAN91C111 code, that can&#39;t be reached.
I couldn&#39;t solve this problem, but if someone got it, please answer this topic. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/rolleyes.gif
Next, the errors I founded.
Nosima
**** Incremental build of configuration Debug for project lwip_web_server_0 ****
make -s all
Compiling echo.c...
Compiling fs.c...
Compiling fsdata.c...
Compiling httpd.c...
Compiling dhcp.c...
../lwip-0.7.1/src/core/dhcp.c:1395: warning: &#39;dhcp_get_option_short&#39; defined but not used
Compiling inet.c...
Compiling icmp.c...
Compiling ip.c...
Compiling ip_addr.c...
Compiling ip_frag.c...
Compiling mem.c...
Compiling memp.c...
Compiling netif.c...
Compiling pbuf.c...
Compiling raw.c...
Compiling stats.c...
Compiling sys.c...
Compiling tcp.c...
Compiling tcp_in.c...
Compiling tcp_out.c...
Compiling udp.c...
Compiling etharp.c...
Compiling loopif.c...
../lwip-0.7.1/src/netif/loopif.c:48: warning: &#39;loopif_input&#39; defined but not used
Compiling lib.c...
Compiling lwip_init.c...
Compiling lan91c111if.c...
../lwip4hal/netif/lan91c111if.c: In function `low_level_output&#39;:
../lwip4hal/netif/lan91c111if.c:76: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:76: error: (Each undeclared identifier is reported only once
../lwip4hal/netif/lan91c111if.c:76: error: for each function it appears in.)
../lwip4hal/netif/lan91c111if.c:76: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c: In function `low_level_input&#39;:
../lwip4hal/netif/lan91c111if.c:185: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:185: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:194: warning: use of cast expressions as lvalues is deprecated
../lwip4hal/netif/lan91c111if.c: In function `lan91c111if_service&#39;:
../lwip4hal/netif/lan91c111if.c:276: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:276: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:276: error: parse error before &#39;)&#39; token
../lwip4hal/netif/lan91c111if.c: In function `low_level_init&#39;:
../lwip4hal/netif/lan91c111if.c:303: error: `alt_avalon_lan91c111_if&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:303: error: `dev&#39; undeclared (first use in this function)
../lwip4hal/netif/lan91c111if.c:303: error: parse error before &#39;)&#39; token
../lwip4hal/netif/lan91c111if.c:311: warning: implicit declaration of function `read_mac_address&#39;
make: *** [obj/lwip4hal/netif/lan91c111if.o] Error 1
Build completed
You&#39;d probably have success if you created a new project in the 6.0 IDE and imported your files from your old project. There&#39;s no guarantee that tranference of projects between versions will work...
Once you&#39;ve created your new project, and copied your files over, you&#39;ll want to ensure that your include paths are set correctly... Go under the C/C++ project settings to look for this.
Best of luck!
- slacker
Thanks for the answer Slacker,
I did that before. Beyond, I recreated my project from beginning in Quartus II 6.0, after I started an C/C++ Project in NIOS II 6.0 with template of Lwip Web Server and I got that error.
I verified paths and other settings.
I think the problem is something related to include file "altera_avalon_lan91c111.h", because all functions from error come from this file.
Other thing I forgot so say is that NIOS II 6.0 point this error to file "lan91c111if.c"
Thanks for the advice,
Nosima
--- Quote Start ---
originally posted by slacker@May 22 2006, 06:24 PM
you&#39;d probably have success if you created a new project in the 6.0 ide and imported your files from your old project.  there&#39;s no guarantee that tranference of projects between versions will work...
once you&#39;ve created your new project, and copied your files over, you&#39;ll want to ensure that your include paths are set correctly...  go under the c/c++ project settings to look for this.
best of luck!
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15510)
--- quote end ---
--- Quote End ---
Nosima
Did you ever get this working. I have hit the same problem and would be
very grateful if you have any help.
- Dyson
--- Quote Start ---
originally posted by nosima@May 22 2006, 09:40 PM
thanks for the answer slacker,
i did that before. beyond, i recreated my project from beginning in quartus ii 6.0, after i started an c/c++ project in nios ii 6.0 with template of lwip web server and i got that error.
i verified paths and other settings.
i think the problem is something related to include file "altera_avalon_lan91c111.h", because all functions from error come from this file.
other thing i forgot so say is that nios ii 6.0 point this error to file "lan91c111if.c"
thanks for the advice,
best regards,
nosima
--- quote start ---
Best of luck!
- slacker
--- Quote End ---
[/b]
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15511)</div>
[/b]
--- Quote End ---
Hi Dyson...
I&#39;ve been trying to get it work but I got no results. I don&#39;t know what to do anymore... it&#39;s really sad...
I will keep trying to get it up...
Nosima
--- Quote Start ---
originally posted by dyson+jun 5 2006, 09:06 am--><div class='quotetop'>quote (dyson @ jun 5 2006, 09:06 am)</div>
--- quote start ---
nosima
did you ever get this working. i have hit the same problem and would be
- dyson
<!--quotebegin-nosima@May 22 2006, 09:40 PM
best regards,
nosima
--- quote start ---
Best of luck!
- slacker
--- Quote End ---
[/b]
--- Quote End ---
[/b]
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15912)</div>
[/b]
--- Quote End ---
TO_BE_DONE
If I copy the LWIP components\altera_avalon_lan91c111\HAL to C:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\HAL I can build the project, but it doesn&#39;t run. Not really sure at this point what the problem is.
--Jordan
Hey...
I&#39;m not getting any succesful result... I have been trying but no results.
I tryied everything you did above, but I found same problems...
I think there is a problems int the sys library... something that I see that the nios 5.1 project system library is diferent...
That&#39;s all
--- Quote Start ---
originally posted by yek401@Jun 28 2006, 03:45 PM
if i copy the lwip components\altera_avalon_lan91c111\hal to c:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\hal i can build the project, but it doesn&#39;t run.  not really sure at this point what the problem is.
--jordan
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16477)
--- quote end ---
--- Quote End ---
I&#39;ve succesfully made it working on NIOS 6.0 by replacing the file
C:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\HAL\inc\altera_avalon_lan91c111.h
by the one found in the archive.
good luck !
--- Quote Start ---
originally posted by gjoli@Oct 5 2006, 02:51 PM
i&#39;ve succesfully made it working on nios 6.0 by replacing the file
c:\altera\quartus60\sopc_builder\components\altera_avalon_lan91c111\hal\inc\altera_avalon_lan91c111.h
good luck !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18560)
--- quote end ---
--- Quote End ---
Where is this archive exectly?
Can you attach the good file?
O.K.
I found my problem at last - I moved the project to seperate workspace from old projects&#39; workspace, and delete the backup of the old altera_avalon_lan91c111 from components folder.
Now the application is working. Still look for how to change IP Address.
Hi Everyone!
As I said, LwIP will not work moreover. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
They said that they will use now NicheStack. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
This way, we will need to pay to develop the new system. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
look this document:
http://www.altera.com/literature/hb/nios2/n2sw_nii52009.pdf (http://www.altera.com/literature/hb/nios2/n2sw_nii52009.pdf
See all! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/cool.gif
hi to all,
of course it is still possible to get standalone Lwip running :
1. Step
Replace the file
C:\altera\61\quartus\sopc_builder\components\altera_avalon_lan91c111\HAL\inc\altera_avalon_lan91c111.h
2. Step
If you have installed the IP megacores !!!
Replace the file
C:\altera\61\ip\sopc_builder_ip\altera_avalon_lan91c111\HAL\inc\altera_avalon_lan91c111.h
archive = in the standalone lwip package "components\altera_avalon_lan91c111\HAL\inc"
-> altera_avalon_lan91c111.h.mtx "delete .mtx"
