dear hippo,
Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,and the nios serial support, then compile : [wangzhiwunpu@localhost linux-2.6.x]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- no emulation specific options. CHK include/nios2_system.h CHK include/linux/version.h SPLIT include/linux/autoconf.h -> include/config/* CC init/main.o CHK include/linux/compile.h CC init/do_mounts.o LD init/mounts.o LD init/built-in.o CHK usr/initramfs_list CC arch/nios2nommu/kernel/signal.o CC arch/nios2nommu/kernel/setup.o CC arch/nios2nommu/kernel/start.o arch/nios2nommu/kernel/start.c: In function `main': arch/nios2nommu/kernel/start.c:523: warning: label `badshiftci_label' defined but not used LD arch/nios2nommu/kernel/built-in.o CC kernel/printk.o CC kernel/exit.o CC kernel/signal.o CC kernel/sys.o CC kernel/power/console.o LD kernel/power/built-in.o CC kernel/acct.o LD kernel/built-in.o CC fs/open.o CC fs/dquot.o CC fs/devpts/inode.o LD fs/devpts/devpts.o LD fs/devpts/built-in.o CC fs/proc/array.o CC fs/proc/proc_tty.o CC fs/proc/proc_misc.o LD fs/proc/proc.o LD fs/proc/built-in.o LD fs/built-in.o CC drivers/char/mem.o drivers/char/mem.c: In function `mmap_kmem': drivers/char/mem.c:276: warning: cast to pointer from integer of different size CC drivers/char/tty_io.o In file included from include/linux/selection.h:11, from drivers/char/tty_io.c:104: include/linux/vt_buffer.h:19:21: asm/vga.h: No such file or directory make[2]: *** [drivers/char/tty_io.o] Error 1 make[1]: *** [drivers/char] Error 2 make: *** [drivers] Error 2Link Copied
You should not follow the old buildroot guide. Do not cd linux-2.6.x to make kernel.
DO NOT MIX UP. Follow the step in the new wiki, http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/uclinuxdist)- Mark as New
dear hippo, when i process the step according to this command:
------------------------------------------ Then <exit> <exit> <yes> . (see LinuxConfig for kernel config items) # compile kernel and apps make make romfs# rebuild kernel for initramfs make linux image ----------------------------------------- when execute the command : [wangzhiwunpu@localhost uClinux-dist-test]$ make sl -lcrypt -lutil -lc xloader.c:31:29: asm/uCbootstrap.h: No such file or directory xloader.c:61: error: syntax error before "m" xloader.c:61: warning: data definition has no type or storage class xloader.c:67: error: syntax error before "header" xloader.c:67: warning: data definition has no type or storage class xloader.c:98: error: syntax error before "program" xloader.c:99: error: syntax error before "program2" xloader.c:100: error: syntax error before "ramload" xloader.c:101: error: syntax error before "setbenv" xloader.c: In function `_bsc1': xloader.c:108: error: syntax error before '*' token xloader.c:114: error: syntax error before '{' token xloader.c:191: error: parameter `err' is initialized xloader.c:195: error: syntax error before "c" xloader.c:367: error: redefinition of parameter 'i' xloader.c:190: error: previous definition of 'i' was here xloader.c:368: error: parameter `bytes_read' is initialized xloader.c:375: error: syntax error before "if" xloader.c:629: error: syntax error before "for" xloader.c:647: error: redefinition of parameter 'statbuf' xloader.c:366: error: previous definition of 'statbuf' was here xloader.c:648: error: redefinition of parameter 'filesize' xloader.c:367: error: previous definition of 'filesize' was here xloader.c:648: error: redefinition of parameter 'i' xloader.c:367: error: previous definition of 'i' was here xloader.c:648: error: redefinition of parameter 'n' xloader.c:367: error: previous definition of 'n' was here xloader.c:649: error: redefinition of parameter 'percent' xloader.c:370: error: previous definition of 'percent' was here xloader.c:650: error: redefinition of parameter 'ferror_image' xloader.c:371: error: previous definition of 'ferror_image' was here xloader.c:653: error: syntax error before "if" make[2]: *** [xloader] Error 1 make[2]: Leaving directory `/home/wangzhiwunpu/uClinux-dist-test/user/boottools' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/wangzhiwunpu/uClinux-dist-test/user' make: *** [subdirs] Error 1 [wangzhiwunpu@localhost uClinux-dist-test]$ thanks!!- Mark as New
1. Did you apply the Nios2 patches to uClinux-dist-test?
cd ~
tar jxf uClinux-dist-test-20060511.tar.bz2
cd uClinux-dist-test
zcat uClinux-dist.diff.gz | patch -p0
2. when you run "make menuconfig" , check if you have the correct target? Vendor/Product Selection ---> --- Select the Vendor you wish to target (Altera) Vendor --- Select the Product you wish to target (nios2nommu) Altera Products then <exit> 3. still in "make menuconfig", try restore to default setting, Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [*] Default all settings (lose changes) [ ] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> 4. "make" again.
dear hippo,
Thank you, when I do according to you i could do next commands successfully, -------------------------------------# compile kernel and apps make make romfs# rebuild kernel for initramfs make linux image ---------------------------------sucessed then i do : http://nioswiki.jot.com/wikihome/operating...x/tryoutuclinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/tryoutuclinux) ------------------- /cygdrive/c/altera [sopc builder]$ nios2-download -g zImage... Using cable "byteBlaster II [LPT1]",device1,instance 0x00 pausing target processor:OK downloaded 745KB in 17.9s<42.1KB/s> Verify failed Leaving target processor pauseed cygdrive/c/altera thanks- Mark as New
It may be
1. problem of sdram timing or hardware, you should run some sdram test or hello on IDE/HAL . 2. byteblaster is not stable, altera recommend usb blaster for nios2 download. Try add termination to jtag signal on your board.- Mark as New
If I were you, I wouldn't try to jump right into uCLinux on a new board. I would start small, with something like "Hello World" or "Count Binary". Be sure that all of your major interfaces (flash, RAM, etc.) function before moving on to anything more complex. There's even a provided example for testing the flash and SDRAM, though you'll have to modify it, slightly, to get it to fully test your system.
It's like building a wall. You wouldn't want to add another layer of bricks to something that isn't solid, would you? Best Regards, - slacker- Mark as New
--- Quote Start --- originally posted by hippo@May 31 2006, 11:15 AM it may be
1. problem of sdram timing or hardware, you should run some sdram test or hello on ide/hal .
try add termination to jtag signal on your board.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15704)
--- quote end ---
--- Quote End --- You have 8MB sdram, you should set boot loader offset to 5M in kernel config. http://nioswiki.jot.com/wikihome/operating...nux/linuxconfig (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux/linuxconfig) cd ~/uClinux-dist-test make menuconfig Kernel/Library/Defaults Selection ---> (linux-2.6.x) Kernel Version (None) Libc Version [ ] Default all settings (lose changes) [*] Customize Kernel Settings [ ] Customize Vendor/User Settings [ ] Update Default Vendor Settings Then <exit> <exit> <yes> <div class='quotetop'>QUOTE </div> --- Quote Start --- If you use DEII with 8M sdram, change the link address of the uncompress loader, Processor type and features-->(0x00500000) Link address offset for booting. The zImage load address is ( your sdram base address + link address offset ) . The zImage boot loader does not relocate itself.[/b] --- Quote End --- Then "make" again.
--- Quote Start --- If you use DEII with 8M sdram, change the link address of the uncompress loader, Processor type and features-->(0x00500000) Link address offset for booting. The zImage load address is ( your sdram base address + link address offset ) . The zImage boot loader does not relocate itself.[/b] --- Quote End --- ==================================== Thanks,I am sure the FLASH and the SDRAM is no problem ,because i tested the hardware and can run UCOS/2 application and other programs. the flash(8MB) base address is 0x000000,the sdram(8MB) base address is 0x800000,so i set the zImage load address :0x500000+0x800000=0x0d00000, and then make ,still has the same problem. why set the link address offset 0x500000? thanks- Mark as New
--- Quote Start --- originally posted by nwpu_zhf2004@May 31 2006, 03:40 PM <div class='quotetop'>quote
--- quote end ---
--- quote start ---
if you use deii with 8m sdram, change the link address of the uncompress loader,
processor type and features-->(0x00500000) link address offset for booting.
the zimage load address is ( your sdram base address + link address offset ) . the zimage boot loader does not relocate itself. --- Quote End --- ==================================== Thanks,I am sure the FLASH and the SDRAM is no problem ,because i tested the hardware and can run UCOS/2 application and other programs. the flash(8MB) base address is 0x000000,the sdram(8MB) base address is 0x800000,so i set the zImage load address :0x500000+0x800000=0x0d00000, and then make ,still has the same problem. why set the link address offset 0x500000? thanks <div align='right'><{post_snapback}> (index.php?act=findpost&pid=15713)</div> [/b] --- Quote End --- Did you "make linux image" ? You should set Link address offset for booting to 0x500000, not 0xd00000 . Kernel config will add up with sdram start. During nios2-download , what is the load address show up? try, nios2-linux-uclibc-objdump -h zImage it should display, .text start from VMA/LMA 0xd00000 .
Thank you very much! you are so intelligent !
I have successed! thank you very much again!!!- Mark as New
for these command:
cd uClinux-dist-test zcat uClinux-dist.diff.gz | patch -p0 i want to known the where the uClinux-dist.diff.gz i should palce! the uClinux-dist-test dir or anywhere???- Mark as New
--- Quote Start --- originally posted by iriver@Jun 4 2006, 09:14 PM for these command:
cd uclinux-dist-test
zcat uclinux-dist.diff.gz | patch -p0
i want to known the where the uclinux-dist.diff.gz i should palce!
the uclinux-dist-test dir or anywhere???
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15882)
--- quote end ---
--- Quote End --- You can place it in uClinux-dist-test, but anywhere should work if you give the path.
hi hippo:
I set Link address offset for booting to 0x500000, but,when i nios2-download,the load address 0x00D000000 show up! I don't know why?- Mark as New
You problem is cuased by the sof. The sof included in the DE2 disc (v1.3,v1.4,v1.5) is no good. You should recompile the sof or use older sof, the one attached in the wiki is v1.1 .- Mark as New
--- Quote Start --- The zImage load address is ( your sdram base address + link address offset ) . You problem is cuased by the sof. The sof included in the DE2 disc (v1.3,v1.4,v1.5) is no good. You should recompile the sof or use older sof, the one attached in the wiki is v1.1 . I use the .sof file you offer, and i download my linux.but i can not work.Then i download the zImage you offer,it can work.So i think the problem may not be cansed by the sof.
Please try "make clean",
Start the make all over again. with "make menuconfig" to default, [*] Default all settings (lose changes)- Mark as New
I try again as you tell me,but there is also the problem!Could you give me a DE2_NET project? This is my EMAIL:li8126@sina.com.
Thanks!!- Mark as New
I follow the step in the new wiki,
http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist (http://nioswiki.jot.com/wikihome/operating...nux/uclinuxdist) Where you guys getting this error: I tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer) but I ran into this error when trying to run make in the uClinux-dist/ fs/buffer.c: In function `__find_get_block_slow': fs/buffer.c:292: warning: long unsigned int format, size_t arg (arg 3) LD fs/built-in.o CC drivers/char/tty_io.o In file included from include/linux/selection.h:11, from drivers/char/tty_io.c:103: include/linux/vt_buffer.h:18:21: asm/vga.h: No such file or directory make[3]: *** [drivers/char/tty_io.o] 错误 1 make[2]: *** [drivers/char] 错误 2 make[1]: *** [drivers] 错误 2 make[1]: Leaving directory `/home/nios/download/uClinux-dist/linux-2.6.x' make: *** [linux] 错误 1- Mark as New
--- Quote Start --- originally posted by liuxiaoping@Apr 2 2007, 08:14 PM i follow the step in the new wiki,
where you guys getting this error:
i tried following the instructions from the wiki http://nioswiki.jot.com/wikihome/operating...ems/framebuffer (http://nioswiki.jot.com/wikihome/operating...ems/framebuffer)
but i ran into this error when trying to run make in the uclinux-dist/
fs/buffer.c: in function `__find_get_block_slow':
ld fs/built-in.o
cc drivers/char/tty_io.o
in file included from include/linux/selection.h:11,
include/linux/vt_buffer.h:18:21: asm/vga.h: no such file or directory
make[1]: leaving directory `/home/nios/download/uclinux-dist/linux-2.6.x'
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22732)
--- quote end ---
--- Quote End --- You must disable these two console, Device Drivers --> Graphics support ---> Console display driver support ---> [ ] VGA text console < > Framebuffer Console support
