dear hippo,
Thank you help me , now i bulild the kernal in my custom board (EP1C6,SDRAM(8MB),FLASH(8MB),uart *2,jtat uart ) ,when i run menuconfig ,i select the ALTERA JTAG UARTsupport,and the nios serial support, then compile : [wangzhiwunpu@localhost linux-2.6.x]$ make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- no emulation specific options. CHK include/nios2_system.h CHK include/linux/version.h SPLIT include/linux/autoconf.h -> include/config/* CC init/main.o CHK include/linux/compile.h CC init/do_mounts.o LD init/mounts.o LD init/built-in.o CHK usr/initramfs_list CC arch/nios2nommu/kernel/signal.o CC arch/nios2nommu/kernel/setup.o CC arch/nios2nommu/kernel/start.o arch/nios2nommu/kernel/start.c: In function `main': arch/nios2nommu/kernel/start.c:523: warning: label `badshiftci_label' defined but not used LD arch/nios2nommu/kernel/built-in.o CC kernel/printk.o CC kernel/exit.o CC kernel/signal.o CC kernel/sys.o CC kernel/power/console.o LD kernel/power/built-in.o CC kernel/acct.o LD kernel/built-in.o CC fs/open.o CC fs/dquot.o CC fs/devpts/inode.o LD fs/devpts/devpts.o LD fs/devpts/built-in.o CC fs/proc/array.o CC fs/proc/proc_tty.o CC fs/proc/proc_misc.o LD fs/proc/proc.o LD fs/proc/built-in.o LD fs/built-in.o CC drivers/char/mem.o drivers/char/mem.c: In function `mmap_kmem': drivers/char/mem.c:276: warning: cast to pointer from integer of different size CC drivers/char/tty_io.o In file included from include/linux/selection.h:11, from drivers/char/tty_io.c:104: include/linux/vt_buffer.h:19:21: asm/vga.h: No such file or directory make[2]: *** [drivers/char/tty_io.o] Error 1 make[1]: *** [drivers/char] Error 2 make: *** [drivers] Error 2Link Copied
- « Previous
- 1
- 2
- Next »
Dear hippo:
I just do as you tell me,and i got the zImage.Then i download the zImage into DE2,but these happened: nios2-download -g zImage Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 pausing target processor http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif K Initializing CPU cache(if present) Downloaded 1440KB in 17.9s (80.4KB/s) Verified OK Starting processor at address 0x005000000 nios2-terminal uncompressing Linux ......OK,booting the kernel. That is all! Where the rest? I enable these: Virtual terminal Support for console on virtual terminal Altera JTAG UART support Support for console on Altera JTAG UART- Mark as New
Good, you are very close.
If I show some config UNSELECTED in the wiki, it means you should not select it. [ ] Support for console on virtual terminal # YOU SHOULD NOT SELECT THIS
- « Previous
- 1
- 2
- Next »
