MIPS processor
HI. I am trying to write a vhdl code for execution of a single clock cycle MIPS processor. But the .scf file is showing me unexpected results. Maybe I am missing something.
The ALU_result is not showing the write result fron the read register data, and PC is not branching. Someone please check it it below and see where I'm wrong.
I am using bit 7 and 6 of the instruction to control the ALU. It needs to do only branch and add, and, + subtract.
Thx
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_SIGNED.ALL;
ENTITY Execute IS
PORT( Read_data_1 : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 );
Read_data_2 : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 );
Sign_extend : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 );
--ALUop : IN STD_LOGIC_VECTOR( 1 DOWNTO 0 );
Zero : OUT STD_LOGIC;
Instruction : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
ALU_Result : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 );
Add_Result : OUT STD_LOGIC_VECTOR( 7 DOWNTO 0 );
PC_plus_4 : IN STD_LOGIC_VECTOR( 7 DOWNTO 0 );
clock, reset : IN STD_LOGIC );
END Execute;
ARCHITECTURE behavior OF Execute IS
SIGNAL Ainput, Binput : STD_LOGIC_VECTOR( 7 DOWNTO 0 );
SIGNAL OP : STD_LOGIC_VECTOR( 1 DOWNTO 0 );
SIGNAL ALU_output_mux : STD_LOGIC_VECTOR( 7 DOWNTO 0 );
SIGNAL Branch_Add : STD_LOGIC_VECTOR( 7 DOWNTO 0 );
BEGIN
Ainput <= Read_data_1;
-- ALU input mux
Binput <= Read_data_2;
OP < = Instruction(7 downto 6);
-- Generate Zero Flag
Zero <= '1'
WHEN ( ALU_output_mux( 7 DOWNTO 0 ) = "00000000" )
ELSE '0';
-- Select ALU output
ALU_result <= "000000" and ALU_output_mux( 7 DOWNTO 0 ) -- FLUSH
WHEN OP = "11"
ELSE ALU_output_mux( 7 DOWNTO 0 );
-- Adder to compute Branch Address
Branch_Add <= PC_plus_4( 7 DOWNTO 0 ) + Sign_extend( 7 DOWNTO 0 ) ;
Add_result <= Branch_Add( 7 DOWNTO 0);
PROCESS ( OP, Ainput, Binput )
BEGIN
-- Select ALU operation
CASE OP IS
WHEN "00" => ALU_output_mux <= Ainput + Binput;
WHEN "01" => ALU_output_mux <= Ainput and Binput;
WHEN "10" => ALU_output_mux <= Ainput - Binput;
WHEN "11" => ALU_output_mux <= Branch_Add;--branch;
WHEN OTHERS => ALU_output_mux <= "00000000" ;
END CASE;
END PROCESS;
END behavior;
i fear this is the wrong forum part for this topic.
Hi Karsten.
Thx 4ur concern. Like I said the simulation was showing unexpected results, the was something wrong with my control signals for the ALU. But I managed to get it right now.
Will post to the proper forum (of which I can't figure out another since this is software) in future.
Sharp sharp...:cool:
