MPU in UP3 board`
I am trying to make use of Memory Protection Unit in NiosII/f core and I am using UP3 development board.
This link http://www.altera.com/literature/an/an540.pdf says that we need to enable it by checking "Inlcude MPU" as shown in figure 1.
But at my end, I am not finding that option(Please refer to snapshot attached with this mail):(
Does that mean UP3 does not support it? :(
Also am using Quartus 10.1...is this a factor..?
Please help...
Amjad
The MPU didn't exist until the December 2009 release. If you're using tools earlier than that...it won't be there.
Cheers,
slacker
^^ Thanks....so its more of a tool problem than development board problem right..?
But am using Quartus 10.1 which is the latest version....
please help...:confused:
I dunno...are you using the "legacy" SOPC Builder (PTF based)? That might be an issue and could happen if your porting an old design forward. I advocate starting from scratch which, in most cases, isn't too hard to do.
See attached image to see what I see when using 10.1 with one of the sample designs.
Good luck!
slacker
Thanks Slacker....yes am indeed using ptf based system. I will look into your suggestion... :)
