12745 Discussions
Macro Indicating NIOS Compilation?
In my code I can do something like:
# ifdef _WIN32 .... # endif
To only include code on a Windows target. Is there a similar symbol that is automatically defined by the NIOS IDE when compiling? I am making a library that I am debugging on Windows and would like to include both NIOS and Windows code separated in this manor, and I would prefer an automatic symbol over a custom made one.
You can define any symbol you want in the build->preprocessor options.
If you don't want to add extra symbols and use default project settings, I think you can exploit ALT_DEBUG and ALT_RELEASE.
--- Quote Start ---
--- Quote End ---
Those might be good... for extra portability across projects I would rather it be something default as opposed to something we assigned.
RTFM:
Try: gcc -E -dM empty_file.c
__NIOS2__
--- Quote Start ---
RTFM:
__NIOS2__
--- Quote End ---
I RTFM, however this detail somehow managed to escape my memory (weird right?)...
Anyways that's what I wanted so I'll let you're smugness slide... This time...
