12745 Discussions
Makefile for simple linux device driver
Contributeur émérite II
2 415 Visites
Hello everyone,
i'm trying to write a device driver. It is an external driver. It should be load with insmod in an running system.
My problem is, that i cannot build the module (I started with a 'Hello Kernel' sample). I have reviewed the documentation, which comes along with the linux distribution. I used following makefile source, which can be found in the doc:
com.microtronix.nios2linux.kernel_1.4.0\linux-2.6.x\Documentation\kbuild\modules.txt
assume this:
- the compiled and build kernel is in D:\MyKernel
- the new module source is in D:\MyModule
- and the linux source is standard path
makefile:
ifneq ($(KERNELRELEASE),)
# kbuild part of makefile
obj-m := mymodule.o
else
# Normal Makefile
# KERNELDIR := /lib/modules/`uname -r`/build
KERNELDIR := D:/MyKernel/Build
all::
$(MAKE) -C $KERNELDIR M=`pwd` $@
endif
Obviously it doesn't work because it tries to build for an x86 architecture
so , i set ARCH and CROSS_COMPILE references in the command line. (Note i use the nios ide, of course)
But it doesn't work. Maybe i didn't understand it correctly. Does someone have a working sample?
I want to use makefile, since i don't want to collect all arch-information and core-depandant in each makefile!
Thank you very much.
0 Compliments
6 Réponses
1 617 Visites
ifneq ($(KERNELRELEASE),)# kbuild part of makefile obj-m := mymodule.o else# Normal Makefile ARCH := nios2nommu CROSS_COMPILE := nios2-elf- KERNELDIR := $(KERNEL_PLUGIN)/linux-2.6.x BUILDDIR := /cygdrive/d/MyKernel all::  $(MAKE) -C $(KERNELDIR) M=`pwd` O=$(BUILDDIR) -O $@ endif
Give the above a try. I added a couple of variables (ARCH and CROSS_COMPILE)... and I've made sure that all you're variables are referenced using the standard $() syntax for Makefiles. Don't forget to add a "TAB" to the $(MAKE) line.
0 Compliments
1 617 Visites
Thank you very much for your quick reply, Ken.
Unfortunately it doesn't work.
Maybe it's good idea to sum up, what i did so far:
1) I created a kernel project, with this external module loading/unloading support enabled:
the project directory with the compiled and build files is located at:
-> d:\MyKernel
2) I made a Linux Filesystem of course
3) To create module project, i used "Linux Application". It is located in:
-> d:\MyModule
The name of .c file is MyModule.c
i do not use the settings und rules files. its just to have project in my workspace.
5) a lot different makefiles
4) I tried your suggested makefile, but it doesn't work. I get a syntax error about the "-O"
so i deleted the "-O" option, and tried again. Now I get following error:
make all
make -C M='pwd' O=/cygdrive/d/MyKernel/build all
make: *** M=pwd: No such file or directory. Stop.
make: *** [all] Error 2
Thanks a lot.
0 Compliments
1 617 Visites
Well, the syntax error with the M='pwd' is because you're using the wrong "ticks".
It should be M=`pwd`... using the backticks.
After fixing the backticks, try putting the O= option back in as well and let me know how it goes. It sounds like you're almost there but not quite.
0 Compliments
1 617 Visites
Thank you again.
the tip the taps took me a step nearer to the goal.. but it still get a syntax error about '-O', it shows me, that in the syntax list isn't an option with cap O but only a tiny 'o' (this time i did a copy&paste to insert your makefile).
After all, i'm still not able build the module (by the way... setting enviromental vars ARCH and CROSS_COMPILE in your makefile doesnt work. It works if i set it in the build command line in the 'Create new make target' menu option.)
With these modification and your suggested make command...
      $(MAKE) -C $(KERNELDIR) M=`pwd` O=$(BUILDDIR) -o $@
...i get:
Nothing to be done for all
After deleting $@ and trying again i get the following output:
make ARCH=nios2nommu CROSS_COMPILE=nios2-elf- all make  -C /cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x M=`pwd` O=/cygdrive/d/MyKernel/build -o all make: Entering directory `/cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux -2.6.x'  no emulation specific options.  LD      /cygdrive/d/MyModule/built-in.o  CC  /cygdrive/d/MyModule/mymodule.o /cygdrive/d/MyModule/.mymodule.o.d: done.  Building modules, stage 2.  MODPOST Signal 11 make: *** Error 139 make: *** Error 2 make: *** Error 2 make: Leaving directory `/cygdrive/d/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux- 2.6.x' make: *** Error 2
In addition the build process adds following files and directories to my project folder:
- a mymodule.o file
- a buit-in.o
- a .built-in.o.cmd file
- a .mod.o.cmd file
- a '.tmp_versions' directory with a 'mymodule.mod' file
Maybe I do every possible mistake, that can be done?
0 Compliments
1 617 Visites
oh geez... I'm so sorry... I didn't even see the -O in the example Makefile I gave. That was a mistake on my part. Sorry for that.
The line should read:
$(MAKE) -C $(KERNELDIR) M=`pwd` O=$(BUILDDIR) modules
aie. That should be what you need.
The MODPOST error is due to "dos linefeeds" in the Modules.symvers file (in your kernel build directory). So you'll need to run the file through dos2unix.
0 Compliments
1 617 Visites
Thank you for help Ken and for your patience with me.
It works... the "dos2unix hint" solved my problem.
Again, thank you very much.
0 Compliments
Répondre
