Manual ethernet settings
hallo ,
Does somebody know how to inintialize ethernet ,after making ethernet settings manuallly in ecos config tool.
thanks,
NIrav
Hi nirav,
First, you should review the description of the the configuration option for
manual configuration (e.g. CYGHWR_NET_DRIVER_ETH0_MANUAL): [emphasis added]<div class='quotetop'>QUOTE </div>
--- Quote Start ---
If this option is selected, the eCos library provides no initialization code
for this interface; you must perform all the initialization in the application,
by means of appropriate ioctl() calls, or by calling init_net() with an
appropriate bootp record you have constructed yourself.[/b]
--- Quote End ---
Second, use the force and review the following in the packages/net tree:
-- sockio.h
-- network_support.c
-- bootp_support.c
It should answer most of your questions.
--Scott
