Memory Test
I was trying to write a simple program to test a board with a Cyclone and SRAM memory. Before hardware, I thought I would do a simple test to the IDT memory on a Cyclone Development Board.
I have defined .text, .rodata, and .rwdata as sram_0 in IDE.
My sram_0 is defined in system.h with a base of 0x00800000 with a width of 1024 Kbytes.
Reset and exception are at 0x00800000 and 0x00800020 respectively as defined in SOPC.
I get the very strange messages about sram_0, my defined memory not being within region .sram_0, and also that sram_0 is full section .bss. What does this mean? Can I use IORD and IOWR for access to Memory or should I be doing something else?
Any tips appreciated.
-Ray
ERRORS:
Kind Status Priority Description Resource In Folder Location
Error /cygdrive/c/Altera/kits/nios21_1/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld address 0xbf8150 of simple_axiom_test.elf section .sram_0 is not within region sram_0 simple_axiom_test line 0
Error /cygdrive/c/Altera/kits/nios21_1/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/bin/ld region sram_0 is full (simple_axiom_test.elf section .bss) simple_axiom_test line 0
CODE:
// test memory# include <stdio.h># include <stddef.h># include <unistd.h># include <fcntl.h># include <stdlib.h>
# include "system.h" // generated header for the SOPC generated logic# include "io.h" // defines IORD, IOWR
//#include "simple.h"
# include "sys/alt_dev.h"# include "priv/alt_file.h"# include "alt_types.h" # include "sys/alt_sys_init.h" // contains reference to "alt_syst_init()"
//#include "myboard.h" // file to put system.h into a easy to read header
//#include "uart.h" // prototypes for the UART functions.
//#define SRAM_MEM_SIZE 1048575 //0x000FFFFF;# define SRAM_MEM_SIZE 1024000 //0x000FFFFF;
//#define SRAM_BASE_0 0x0080;
volatile unsigned long MEMORY_READ; // ??? what is 32 bits long for altera types
//unsigned long *SRAM_BASE_0;
//unsigned long SRAM_BASE_0;
//volatile unsigned long FAILED_ADDRESS;
//volatile unsigned long REC_DATA;
int main(void)
int i;
int err_flag;
static unsigned long MEMORY_ARRAY[SRAM_MEM_SIZE];
printf("Hello from Nios II!\n");
err_flag = 0;
//Fill SRAM Base Memory with all a&#39;s first
for (i=0; i<SRAM_MEM_SIZE; i = i + 4)
//Writes
//IOWR((unsigned long *)(SRAM_BASE_0), i ,0xAAAAAAAA);
IOWR(0x00800000, i, 0xAAAAAAAA);
// Read
MEMORY_READ = IORD(0x00800000, i );
// Store in an array
MEMORY_ARRAY=memory_read;
// if expected results match proceed otherwise set err_flag
// capture address that fails and break out of test
// set error flag to -1
for (i=0;i<sram_mem_size;i = i + 4)
if( memory_array != 0xAAAAAAAA)
err_flag = -1;
REC_DATA = MEMORY_ARRAY
failed_address = i;
//fill sram base memory with all 5&#39;s first
for (i=0; i<3; i++) // how do increase by 4
//writes
iowr(0x00800000, i ,0x55555555);
for (i=0; i<sram_mem_size; i = i + 4)
// read
memory_read = iord(0x00800000, i );
// store in an array
memory_array=MEMORY_READ;
// If expected results match proceed otherwise set err_flag
// Capture Address that fails and break out of test
// Set error flag to -1
if( MEMORY_ARRAY != 0x55555555)
err_flag = -2;
rec_data = memory_array
FAILED_ADDRESS = i;
if ( err_flag < 0)
if( err_flag == -1)
printf(" Memory Test Failed @ Address = %x \n", FAILED_ADDRESS);
printf(" Received data = %x \n", REC_DATA);
printf(" Expected data = %x \n", 0xAAAAAAAA);
if( err_flag = -2)
printf(" Expected data = %x \n", 0x55555555);
else
printf("All Memory Tests PASSED!\n");
printf("End of Program \n");
return(0);
Hi Ray,
You don&#39;t have enough space in your .sram_0 section:
requires almost 4 MB in the output section. Other data,
library code and app code gets added in as well (assuming
everything is being placed in the SRAM).
--Scott
-Ray
