Hi all,
cyg_mbox_peek (), is always returning the count 1 less than the actual number of messages in the message box. When the message box is empty, then count is returned as 0. Why this is so? I am attaching the code below for reference. With regards, Sanjay /* **** Include standard header files **** */# include <cyg/kernel/kapi.h># include <cyg/infra/diag.h> /* **** Constants **** */# define TRUE 1 /* Size of a task's stack */# define STACKSIZE (CYGNUM_HAL_STACK_SIZE_TYPICAL + 4096)# define NTHREADS 2 /* No. of threads */ /* **** User-defined data types **** */ typedef char stack_t; /* Each stack entry is 8-bit wide */ /* **** Function prototypes **** */ void task_a (cyg_addrword_t); void task_b (cyg_addrword_t); /* **** Gobal variables **** */ cyg_thread task_housekeeping_info[NTHREADS]; stack_t task_stack[NTHREADS+1][STACKSIZE]; cyg_handle_t mbox_handle; cyg_mbox mbox; int msg1=12, msg2=24; /* Startup function */ void cyg_user_start () { cyg_handle_t task_handle[NTHREADS]; cyg_mbox_create (&mbox_handle, &mbox); cyg_thread_create (0, task_a, (cyg_addrword_t) 0, "task_a", (void *) task_stack[0], STACKSIZE, &task_handle[0], &task_housekeeping_info[0]); cyg_thread_create (0, task_b, (cyg_addrword_t) 1, "task_b", (void *) task_stack[1], STACKSIZE, &task_handle[1], &task_housekeeping_info[1]); cyg_thread_resume (task_handle[0]); cyg_thread_resume (task_handle[1]); cyg_scheduler_start (); } void task_a (cyg_addrword_t data) { cyg_bool_t stat; long count; // Run this thread forever. while (TRUE) { // Delay for 1000 ticks. cyg_thread_delay (1000); count = cyg_mbox_peek (mbox_handle); diag_printf ("Count = %ld\n", count); // Send a message to Thread B. cyg_mbox_put (mbox_handle, &msg1); cyg_mbox_put (mbox_handle, &msg1); count = cyg_mbox_peek (mbox_handle); diag_printf ("Count = %ld\n", count); } } void task_b (cyg_addrword_t data) { void *message; // Run this thread forever. while (TRUE) { // Wait for the message. message = cyg_mbox_get (mbox_handle); // Make sure we received the message before attempting to process it. if (message != NULL) { // Process the message. diag_printf ("Message: %d\n", *((int*)message)); } } }Link Copied
--- Quote Start --- originally posted by sanjay822@Dec 22 2005, 08:45 AM hi all,
cyg_mbox_peek (), is always returning the count 1 less than the actual number of messages in the message box. when the message box is empty, then count is returned as 0. why this is so?
i am attaching the code below for reference.
with regards,
sanjay
/* **** include standard header files **** */# include <cyg/kernel/kapi.h># include <cyg/infra/diag.h>
/* **** constants **** */# define true 1
/* size of a task's stack */# define stacksize (cygnum_hal_stack_size_typical + 4096)# define nthreads 2 /* no. of threads */
/* **** user-defined data types **** */
typedef char stack_t; /* each stack entry is 8-bit wide */
/* **** function prototypes **** */
/* **** gobal variables **** */
cyg_thread task_housekeeping_info[nthreads];
stack_t task_stack[nthreads+1][stacksize];
cyg_mbox mbox;
/* startup function */
cyg_handle_t task_handle[nthreads];
(void *) task_stack[0], stacksize, &task_handle[0],
(void *) task_stack[1], stacksize, &task_handle[1],
cyg_bool_t stat;
long count;
// run this thread forever.
while (true)
// delay for 1000 ticks.
diag_printf ("count = %ld\n", count);
// send a message to thread b.
void *message;
while (true)
// wait for the message.
// make sure we received the message before attempting to process it.
if (message != null)
// process the message.
diag_printf ("message: %d\n", *((int*)message));
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11736)
--- quote end ---
--- Quote End --- Sanjay, have a look on page 75/76 in the "eCos Reference Manual": cyg_mbox_get () is a blocking function. The thread is woken up immediately after the 1. call of cyg_mbox_put () and empties the mailbox. the 2. cyg_mbox_put () increments the counter again to "1". I am using a "timed put " to send and a "try get" to read for not blocking the threads. Also an additional acknowledge flag is usful to synchronize the threads. Regards, Sepp
--- Quote Start --- --- Quote Start --- Hi, Thanks Sepp for your suggestion. The program is giving correct results now, using cyg_mbox_tryget () instead of cyg_mbox_get (). But still I have one doubt. The reason that you had specified for cyg_mbox_get () is okay, but then using that concept cyg_mbox_peek () would always had returned the count as 0? With regards, Sanjay
Thanks Sepp for your suggestion. The program is giving correct results now, using cyg_mbox_tryget () instead of cyg_mbox_get (). But still I have one doubt. The reason that you had specified for cyg_mbox_get () is okay, but then using that concept cyg_mbox_peek () would always had returned the count as 0? With regards, Sanjay Sanjay, I am not using the function cyg_mbox_peek () so I have no idea. What I am doing is something like this and it works fine: sending thread: while(1) { ... // when a message should be sent: if(!cyg_mbox_timed_put(mbox_hdl,(void *)psMsg1,1000)) { psMsg1 = NULL; // Do something to resend the message } else { // wait for acknowledge ret = cyg_flag_wait(&FlgAckMsg,FLG_MBOX_ACK,CYG_FLAG_WAITMODE_AND | CYG_FLAG_WAITMODE_CLR); } ... } receiving thread: while(1) { ... // allways have a look if there is a new message pMsg= cyg_mbox_tryget(mbox_hdl); if(pMsg2 != NULL) { save message: // Saving the message data into a local struct acknowledge: cyg_flag_setbits(&FlgAckMsg,FLG_MBOX_ACK); work with received data: // Decoding the received message and do some action with it } ... } Regards, Sepp
