MicroC-OSII mutexs
does anyone know if you can define multiple mutexs in microC OS 2?
I have more than one shared resource that I would like to have different semaphores for. But I would like to use mutex semaphores.
Based on the microC OS 2 book, it seems like you can only make 1 mutex :confused:
am i missing something?
maybe he has a mistake in his example in chapter 8.1 of his book?
He has a line of code that says
OSMutexCreate(9,&err);
I think maybe this should read
ResourceMutex = OSMutexCreate(9,&err);
I guess the question is do you need to create an OS_EVENT* type and set it eqaual to OSMutexCreate() ?
It must just be a mistake in the documentation. Can someone confirm?
My uC/OS-2 manual reads
DispMutex = OSMutexCreate(20, &err);
Based on this i see no reason why there should be not more then 1 Mutex in a System.
What you need to do is reserve enough space for the event control blocks in the system lib settings.
karsten
thank you, yes I believe you are correct.
