Mixing Verilog and VHDL
I have to connect logic written in Verilog with logic written in VHDL.
I've tried with Quartus 4.1.
here is the code of the Verilog file:
dsp_dummy    dsp_dummy_inst (     .clock ( clock ),     .reset ( null ),     .enable ( eins ),     .stall ( null ),     .wb_dat_io ( wb_dat_io ),     .wb_adr_i ( address_mem ),               .wb_we_i ( wb_we_i ),     .wb_stb_i ( wb_stb_i ),     .wb_ack_o ( wb_ack_o )          );
I've added the file dsp_dummy.vhdl to the project. When I try to compile it, I get the following error:
Error: Node instance dsp_dummy_inst instantiates undefined entity dsp_dummy
I don't know, what I've done wrong. Can anyone help me?
check the bdf or the pin list.
That's the error I get when I don't have something hooked up right.
