More kernel compile problems
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif Sill using Quartus 4.0 with Nios 3.2 and Microtronix v. 1.3
When compiling the kernel in my project directory. I receive an error...
"entry.S:210: Error: non-constant expression in ".if" statement."
This error is repeated 34 times before the compiler quits.
This error is preceeded by a warning...
"In file included from entry.S:18:
<path to asm/asm-niosnommu>/ptrace.h:74:30:
warning: REGWIN_SZ redefined
nios_defs.h:24:17: warning: this is the location of the previous definition"
In entry.s, line 210 is the next line after the block of code... ".ifdef na_ide_interface... .endif"
I once hae IDE support included in the kernel but have since removed it since my hardware design no longer has an IDE interface.
I don&#39;t yet know if the warning is connected to the error.
Any ideas??
Nick
