Dear all,
Currently I'm using three DMAs in my SOPC system to handle three different data transfers from three different FIFOs to a DDR3 memory. I have verified each FIFO and DMA data transfer and all of them work well. The problem occurs when I put all FIFOs and DMAs in one SOPC system design. :( I ran the DMA data transfer in sequence (not parallel). Somehow my Nios software hung / stopped. The Nios software might stop in different location, but mostly it stopped when it tried to open the DMA ('alt_dma_rxchan_open' function) or when it checked the DMA data transfer volatile indicator variable. :confused: Does anyone can help me to figure out what the exact problem is ? Thanks ... looking forward any replies from you guys! :)Link Copied
Hello, i need to use a DMA to transfer from a FIFO to a DDR2. Do you have any reference design? Thanks!
Topic Options
