12748 Discussions
Multiple Triple Speed Ethernet with microOS II and interniche
Anybody can tell me how to set the driver to handle multiple TSE in the Nios II software?
I have Nios II EDS 9.0 sp2, running microOS II with interniche.. As soon as I have 2 TSE Ethernet defined, my system crashed upon execution or when any data coming from the ethernet.
Anybody can help?
Best,
E1
i have done this before without error, this may be some specific configuration issue.
--dalon
Did you remember if you need to set any parameters or definition to have run?
According to Interniche, we only need to enable the MULTI_HOMED and IP_ROUTING definition.
Appreciate if you can help..
Best,
did not have to do anything. I made one minor modification to the driver to allow me to easily determine which TSE was which, but that is it.
Are these 2 entirely separate TSEs with independent SGDMA's or a shared FIFO implementation?
--dalon
Either way, it gave me the same problem.. What setting you did?
I found that tse_mac_device structure array of 4, was only filled with 1 TSE structure address, which is the second ethernet. The first ethernet were never initialized..
So when it received message, it ran an invalid instruction (wildcard instruction).
