12748 Discussions
Multiprocessor using DE2-70 board
Hello all,
I want to design multiprocessor project using DE2-70(EP2C70F896C6N).
I am getting pin assignment error as :
Quartus II
I/O Assignment Analysis was NOT successful (50 errors)
OK
Info: *******************************************************************
Info: Running Quartus II Fitter
Info: Version 7.2 Build 151 09/26/2007 SJ Full Version
Info: Processing started: Fri Jun 04 19:13:38 2010
Info: Command: quartus_fit --read_settings_files=on --write_settings_files=off NiosII_cycloneII_2c35_standard -c NiosII_cycloneII_2c35_standard --check_ios
Info: Selected device EP2C70F896C6 for design "NiosII_cycloneII_2c35_standard"
Info: Low junction temperature is 0 degrees C
Info: High junction temperature is 85 degrees C
Info: Implemented PLL "NiosII_cycloneII_2c35_standard_sopc:NiosII_cycloneII_2c35_standard_sopc_instance|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|pll" as Cyclone II PLL type
Info: Implementing clock multiplication of 17, clock division of 10, and phase shift of 0 degrees (0 ps) for NiosII_cycloneII_2c35_standard_sopc:NiosII_cycloneII_2c35_standard_sopc_instance|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk0 port
Info: Implementing clock multiplication of 17, clock division of 10, and phase shift of -103 degrees (-3382 ps) for NiosII_cycloneII_2c35_standard_sopc:NiosII_cycloneII_2c35_standard_sopc_instance|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk1 port
Info: Implementing clock multiplication of 17, clock division of 10, and phase shift of 270 degrees (8824 ps) for NiosII_cycloneII_2c35_standard_sopc:NiosII_cycloneII_2c35_standard_sopc_instance|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2 port
Error: Can't place node "LCD_data_to_and_from_the_lcd_display[0]" -- illegal location assignment PIN_R19
Error: Can't place node "LCD_data_to_and_from_the_lcd_display[1]" -- illegal location assignment PIN_T19
Error: Can't place node "LCD_data_to_and_from_the_lcd_display[2]" -- illegal location assignment PIN_U20
Error: Can't place node "LCD_data_to_and_from_the_lcd_display[3]" -- illegal location assignment PIN_U21
Error: Can't place node "LCD_data_to_and_from_the_lcd_display[4]" -- illegal location assignment PIN_V26
Error: Can't place node "LCD_data_to_and_from_the_lcd_display[5]" -- illegal location assignment PIN_V25
Error: Can't place node "bidir_port_to_and_from_the_reconfig_request_pio" -- illegal location assignment PIN_AA14
Error: Can't place node "ext_flash_enet_bus_data[1]" -- illegal location assignment PIN_C8
Error: Can't place node "ext_flash_enet_bus_data[2]" -- illegal location assignment PIN_F10
Error: Can't place node "ext_flash_enet_bus_data[21]" -- illegal location assignment PIN_J14
Error: Can't place node "ext_flash_enet_bus_data[24]" -- illegal location assignment PIN_J10
Error: Can't place node "ext_flash_enet_bus_data[25]" -- illegal location assignment PIN_J11
Error: Can't place node "ext_flash_enet_bus_data[26]" -- illegal location assignment PIN_C11
Error: Can't place node "ext_ssram_bus_data[14]" -- illegal location assignment PIN_J3
Error: Can't place node "ext_ssram_bus_data[15]" -- illegal location assignment PIN_J4
Error: Can't place node "ext_ssram_bus_data[30]" -- illegal location assignment PIN_J8
Error: Can't place node "LCD_RS_from_the_lcd_display" -- illegal location assignment PIN_T18
Error: Can't place node "LCD_RW_from_the_lcd_display" -- illegal location assignment PIN_T17
Error: Can't place node "bwe_n_to_the_ext_ssram" -- illegal location assignment PIN_J9
Error: Can't place node "byteenablen_to_the_lan91c111[0]" -- illegal location assignment PIN_C25
Error: Can't place node "ddr_a[5]" -- illegal location assignment PIN_U10
Error: Can't place node "ddr_a[7]" -- illegal location assignment PIN_V1
Error: Can't place node "ddr_a[11]" -- illegal location assignment PIN_T10
Error: Can't place node "ext_flash_enet_bus_address[0]" -- illegal location assignment PIN_F9
Error: Can't place node "ext_flash_enet_bus_address[2]" -- illegal location assignment PIN_D11
Error: Can't place node "ext_flash_enet_bus_address[6]" -- illegal location assignment PIN_F14
Error: Can't place node "ext_flash_enet_bus_address[21]" -- illegal location assignment PIN_F15
Error: Can't place node "ext_ssram_bus_address[13]" -- illegal location assignment PIN_C6
Error: Can't place node "ext_ssram_bus_address[14]" -- illegal location assignment PIN_A4
Error: Can't place node "out_port_from_the_led_pio_n[0]" -- illegal location assignment PIN_AC10
Error: Can't place node "out_port_from_the_led_pio_n[1]" -- illegal location assignment PIN_W11
Error: Can't place node "out_port_from_the_led_pio_n[2]" -- illegal location assignment PIN_W12
Error: Can't place node "out_port_from_the_led_pio_n[7]" -- illegal location assignment PIN_AA11
Error: Can't place node "out_port_from_the_seven_seg_pio[2]" -- illegal location assignment PIN_AE10
Error: Can't place node "out_port_from_the_seven_seg_pio[5]" -- illegal location assignment PIN_V13
Error: Can't place node "out_port_from_the_seven_seg_pio[6]" -- illegal location assignment PIN_V14
Error: Can't place node "out_port_from_the_seven_seg_pio[8]" -- illegal location assignment PIN_V11
Error: Can't place node "out_port_from_the_seven_seg_pio[9]" -- illegal location assignment PIN_Y12
Error: Can't place node "out_port_from_the_seven_seg_pio[10]" -- illegal location assignment PIN_AA12
Error: Can't place node "out_port_from_the_seven_seg_pio[13]" -- illegal location assignment PIN_AF13
Error: Can't place node "out_port_from_the_seven_seg_pio[15]" -- illegal location assignment PIN_U12
Error: Can't place node "pll_c1_out" -- illegal location assignment PIN_E5
Error: Can't place node "read_n_to_the_ext_flash" -- illegal location assignment PIN_F17
Error: Can't place node "txd_from_the_uart1" -- illegal location assignment PIN_J22
Error: Can't place node "in_port_to_the_button_pio[0]" -- illegal location assignment PIN_Y11
Error: Can't place node "in_port_to_the_button_pio[2]" -- illegal location assignment PIN_AB10
Error: Can't place node "in_port_to_the_button_pio[3]" -- illegal location assignment PIN_AE6
Error: Can't place node "irq_from_the_lan91c111" -- illegal location assignment PIN_AA15
Error: Can't place node "rxd_to_the_uart1" -- illegal location assignment PIN_AB15
error: can't fit design in device
Error: Quartus II I/O Assignment Analysis was unsuccessful. 50 errors, 0 warnings
Info: Allocated 226 megabytes of memory during processing
Error: Processing ended: Fri Jun 04 19:15:11 2010
Error: Elapsed time: 00:01:33
Can I know why this error occurs?also Error highlited above"error: can't fit design in device" ?
I have tried a lot with pin assignments .by importing .qsf file .But still getting the same error.
It looks like you are compiling a design made for a 2c35 Cyclone into a 2c70. Are you sure the design you are compiling is for the DE2-70 and not the regular DE2? I don't know if the two boards are pin-to-pin compatible.
Thank you I got the solution.
I have compiled it correctly bou getting time limited sof file. can you please tell me what is time limited sof file.
Is it necessary to have a paid license for the software for device prograaming(i.e. Generating valid .sof file)? oR WB EDITION perform properly?
also when I program using time limited .sof file I am getting error message in Nios II IDE as processor not responding whan running the Hello world.c program. Can you plaese giude me?
