12748 Discussions
My PCB design for Cyclone II ep2c20F484;ep2c35F484
I am begginer ir FPGA and the problem I have is with these development bords is that they are very expensive! cheapest bord I found with cyclone II ep2c20 FPGA is firefly bord with cost 350$ and its too expensive and second problem is that these FBGA chips is olmost inposible solder by hands soldering wires to pins.
Only solution is to make PCB and there is third problem that this PCB trace width is wery small 8mils (0.2mm) and ALTERA recomended trace width for PCB is 5mils (0.12mm) and drill hole 8mils (0.2mm) so not all PCB manufacturers can make these PCB and 4 leyer PCB is almost 2.5 times expensiver than 2 leyer PCB.
And I calculated that for me and my frend buying 2bords will cost 700$ and making my own PCB will be mutch cheaper about 300$ for PCB and 100$ for FPGA and ather components.
here is a picture of unfinished PCB
http://theonlyway.net/eoz/upload/attachment.php?attachmentid=678&d=1153642561
if you don't see the picture go to this link http://theonlyway.net/eoz/upload/attachmen...78&d=1153642561 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=678&d=1153642561) (it is a forum Where I posted the picture)
There will be availible all IO pins and special purpose pins like those for programming and on bord JTAG conection, 16Mb configuration FLASH, and Power suply circruit for core 1.2V and for IO pins 3.3V
on this bord will be for 3 cyclone devices EP2C20F484;EP2C35F484;EP2C50F484
In 3 PCB leyers I routed out 90 pins on one side so totaly In 3 leyers it is posible to route out 360 pins http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif of FBGA484 package and 4th leyer will be GND and VCC
I am designing this PCB about 2 weaks and previously I designed FBGA 256 package in 2 leyers for EP2C20F256C8 device.
Picture of almost complete 2 leyer PCB designe for EP2C20F256C8 device.
http://theonlyway.net/eoz/upload/attachment.php?attachmentid=676&d=1153473055
if dont see image go to
http://theonlyway.net/eoz/upload/attachmen...76&d=1153473055 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=676&d=1153473055
Wen I will finish my designe I will post the picture.
So what you think about my PCB designe is there somthing I missed ?
I plan to develop CNC motion controller to syncronise 4 stepper motors and 1 AC motor with Quadrature encoders, and I olready developed code for motor sinhronization for ATMEL microcontroller Mega128 but it don&#39;t work in device and there is too small periperals like PWM generators, 16bit timers, and Input Capture units for all operations thats why I plan to lern FPGA becose ther is no limits you can make so mutch periperals as you need http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif .
Hi Epis:
It&#39;s very important to add series resistor to all JTAG signals and also a 10nf(may be a little bit higher) capacitor near the FPGA pin. The value of the serier resistor maybe will have to be adjust althogh a 47ohm for TDO and 0ohn for the rest can be a good starting point.
Bye,
Luis
i did a migration board with ep2c20f484 and ep2c50f848 both i8n types.
what i miss in your pcb is a proper powersupply layout. those traces conneting vio and vcore are inductance with pure impedance controled traces. imagine what will happen if several hundred or more dff inside your fpga switch from 0 to 1 or vice versa each of them with serveral mA up to hundert mA currents for a few nsec that will lead to a current peak of serveal A/nsec and if you take into account that your voltage ripple has to stay within a few mV you will need caps with low esr.
C(F)=I(A) x t(nsec) / U (V) where U is the max allowed voltage ripple for a time t with a current I. F is As/V
if you now look at these smal traces for the vcore and vio pins and even the gnd pins .... i doubt that you will run a stable design without taking care about gnd bounce over and undershots .... they can lead to uncontrolled switching of your logic as they move the voltage levels for a short time.
My pcb for these FPGAs has 14 Layer and does not need any emc screening to pass emc and etsi approval when running under full load @ 64MHz clock. all signals are impedance controlled. the layout is the key factor for this stable design.
If you have a look at the pcb design guides from altera and xilinx and other you will see that they do not take into account what is realy needed for a stable AND emc bullet proof design. Some of the hints and tips are realy false.
Michael Schmitt
Thank you for suggestions !
I thought that grounding would be a problem but in thouse ALTERA Power supply articles like http://www.altera.com/support/devices/powe...-integrity.html (http://www.altera.com/support/devices/power/integrity/pow-integrity.html
there is text of that article &#39;&#39;Designers should add as many 0.2 µF power-supply decoupling capacitors as possible to the VCCINT, VCCIO, and ground pins/planes. Ideally, these small capacitors should be located as close as possible to the device. Designers can decouple each VCCINT or VCCIO and ground pin pair with a 0.2-µF capacitor. If a design uses high-density packages such as ball grid array (BGA) packages, it may be difficult to use one decoupling capacitor per VCCINT / VCCIO and ground pin pair. In such cases, designers make every effort to use as many decoupling capacitors as allowed by the layout. Decoupling capacitors should have a good frequency response, such as monolithic-ceramic capacitors.&#39;&#39;
In this FBGA 256 PCB designe http://theonlyway.net/eoz/upload/attachmen...76&d=1153473055 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=676&d=1153473055
I have place for 9 ceramic capacitors on the Bottom layer for VCC INTernal and For VCC IO I have place for 8 ceramic capacitors on the top layer isn&#39;t that enough for EP2C20F256 device if these capacitors are 0.1-0.2uF.
Until now I planed to place in my big FBGA484 PCB desine these small 0.1-0.2uF capacitors as meny as posible in 4th bottom leyer (under FPGA), or I need to make 6 layer PCB 5th layer could be VCC and 6th layer GND.
I planed to use LM2679 ADJ 1.2V 5A Step-down Voltage regulator for internal power supply and for I/O LM2673 3.3V 3A Step-down Voltage regulator as in National Altera designe guide pdf for cyclone FPGA.
It is not only the value of the caps.
maybe i can illustrate the current peaks and what this means with the following ...
imagine you through a stone into the middle of a sea.
The stone is the current peak and the sea is your power supply system.
the current peak is due to switching inside the fpga and other parts.
if it summer, the sea is liquid. The stone will hit the surface and big waves will go out from the impact point. you will see min and max ... same with you power supply the voltage will over and undershot and raise some kind of ringing.
your power supply is too weak
if it is winter, the sea is frozen. the same stone wil hit the same place of the surface with the same energie. the stone will jump up and down ... now think of your power supply system ... not good either
the best is if this sea is like a moor. the same stone will hit the surface and vanish away without resulting waves or a jumping stone. the best solution.
of course you need the big caps. imagine a water supply system for a city. these water tanks will feed the waterpipes (your tracks) but if somebody opens a valve the preasure drops inside that pipe (the voltage on your track)
your smal tracks have to carry the whole current that needs to be delivered to hold the voltage on each fpga pin. i guess you cant do that with traces, you need to do that with power planes. one for each voltage and gnd. these form a capacitor (made by the pcb). the smal caps with a few nF to uF are for haveing low impedance over a wider frequency range.
the fpga 484 footprint needs 5 routing layers to gain access to the inner pins.
how much routing layers are needed for the f256 cant say that out of my head.
I have used the LM2677S-3.3 and a LT3412A for 1.2V a perfect combination here.
a layerstack for the f484 could be
top
gnd
1v2
gnd
3v3
gnd
s1
s2
gnd
s3
s4
gnd
s5
bot
but with 6 layers i cant see a working solution that is stable and will pass all aproval tests.
Michael
I found wery clever solution to reduce your suggested 14 layer designe to 7-8 leyer design by making wery smart design.
Before I will tell my new teory of PCB making look at Sendero Evaluation kit bay microtroniX price 895$ in this Evaluation kit PCB layout they hade only one GND Layer and 2 VCC layers ather were signal layers and totaly they have 8 layer PCB.
So Question is how can they make sutch designe? or they PCB is total garbage!
I read in microtronix home page that they have cutting-edge hardware and software solutions then these sendero bord isn&#39;t total garbage and they use big EP2C35F672 device and how then about theyr firefly bords do they olso have 8 layer PCB.
And here is my new PCB routing theory to reduce number of GND planes we can implement these GND fields in signal layer free spaces so 8 layer designe would lock like this:
Top (signal layer 1 and GND)
Signal 2 (gnd)
Signal3 (GND)
Signal 4 (GND)
Signal 5 (GND
Signal 6 (GND)
VCC core (and few signals if there are left some not conected pins)
VCC I/O (and few signals if there are left some not conected pins)
ToTALY we have 6 GND Layers http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif witch is combined with signal layers but to do that we neede to make 4 lines in eatch signal layer to central GND pin block and this is done bay unrouting 3 pins in each side so totaly we will loose 12 pins per layer but as in the end we increase signal layer count bay 3 these lost pins we will route in theas layers.
And I think that it is posible to make even 7 layer bord 5 GND and 2 VCC layers as you suggested, but only combined with Signal layers and finaly it wil be 2 times cheaper than making 14 layer bord! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
I think that this is the best solution!
I see the point of reducing the cost for each additional layer pair.
but filling the gaps with gnd polygons is not a power plane.
you will lose the profits you get from a real powerplane design such like low impedance over a wide frequency range. Image a clock of 50Mhz. 50MHz is the first frequency and just a pure sine wave. to reach a rectangle clock shape you need the upper higher frequencies like 150 250 ... so the 5th will give you 250MHz and that means your design must handle at least 250MHz bandwidth.
of course you can get design working with as less a possible layers, but i have seen a couple of pcb&#39;s that still work but have no chance to pass emc tests without shielding, ferrit beats and all these expensive stuff. we did the calculation too and we ended up that the 14layers is the cheapest solution over all to get a design that is industrial bullet proof and passes all tests with no metal housing or any shielding. and the peaks are far away from the emc or etsi limits.
filling gaps with gnd can make things more worse as you need to contact them with low impedance to each other, if not you layout some antennas and believe me they will do their job very good and radiate around :-) imagine even a via is a kind of an inductor between your gnd fills with a few pH and a few pF and a bit R so you have R L C what leeds to resonance ...
keeping an eye on the layer stack has on one side the costs for the additional layers but on the other hand you save a lot of caps you do not need to spread around the board. i have a dozend of mlc (each 100uF 6V3 1210size) around the whole pcb and 8 caps 0402 size as a calculated capacitor bank to control the power supply impedance. the copper is there just use it :-) the distance between the layers is also very important. having a distance of 100um between the layers gives you a good power plane but moving to 50um a much better as you gain the goals of field effects between them. but that goes to far here to explain, this is a fpga forum and not an emc.
if i would layout a pcb for my own purpose and will never go to any aproval test i would also try to get rid of any layer pair i can.
take care about the power supply, you will go nut if you try to find out why your design does funny things due to over and undershots. but the fpga&#39;s give you the possability to control the current of each pin.
for your layer stack ...
try to have the two power supply layers vcc vio between gnd
signal (gnd)
vcore
signal (gnd)
vcc
signal (gnd)
in this case each power layer has two gnd&#39;s one above and the other underneath so you double the cap, halve the impedance .... if your signal does not brake your gnd fills too much
also try to have vcore next to the fpga top layer.
place additional vias to connect the gnds vcc vore tracks fills ... as much as you can to lower the impedance. each signal (track) has a current that travels along this track, but always has a current that goes back ...
Michael Schmitt
Now I will rework my desine (will put larger via holes in central GND block) and then will see if my designe will fit in 6,7 or 8 layers.
6 layer : 8 layer:
signal (gnd) signal (gnd)
gnd only gnd only
vcore (few signal) vcore (few signal)
vcc (few signal) signal (gnd)
signal (gnd) vcc (few signal)
gnd only
signal (gnd)
As I will make les than 50 bords than this leyer count is wery important for me becose price gets significantly higher bay eatch leyer.
here is price comparison of 6,8 leyer bords in PCBCART.com bord size 65mmx75mm, if I make 50 bords then prices are:
6layer;
590$ (1bord 11.8$)
8layer:
862$ (1bord 17.2$)
the diference in price for 1 bord is 5.4 $ and for sutch money I could buy lot of EMI filters for propper grounding.
If I will make fewer bords then this price diference will grow betwen 6 and 8 layer bords. But in high volium production diference will decrease then ofcourse it is cheaper to make 8, 10,.. 14 layer bords without emi filters that reduces total bord cost!
I read some articles about EMI filters and found murata emi noise suppression filters and these chip ferrite beads (which isn&#39;t so expensive just 0.03$) could be solution if ground plane can&#39;t handle EMI. So I will leave place for these SMD chip emi filters.
Now I decided to make 4layer PCB for ep2c20f256 ep2c8f256 and ep2c5f256 insted of 8layer PCB for ep2c20;35;50 in FBGA484 package becose its to expensive and I dont now how big device I will need, so a good starting point would be ep2c20 in smaler FBGA 256 package.
As I already have routed in 2 layers ep2c20f256 device then i will need to add ground planes and VCC INT,i/o plane.
How much layers these small FPGAs need 4 or 6 ?
If I will need in future larger device then I will make PCB for FBGA672 package becose it covers larger devices than FBGA484.
Wen I will route mu nev 4 layer or 6 layer PCB the I will post link to pictures.
my god, 14 layers is way too much... you can get a 256BGA on a 6-layer, 4-layer if you don&#39;t hav etoo much high speed stuff.
484 can get on a 6-layer very easily. I have put a 672 on an 8-layer, but it could have been dropped to 6 possibly.
--- Quote Start ---
originally posted by epis@Jul 30 2006, 05:36 PM
now i decided to make 4layer pcb for ep2c20f256 ep2c8f256 and ep2c5f256 insted of 8layer pcb for ep2c20;35;50 in fbga484 package becose its to expensive and i dont now how big device i will need, so a good starting point would be ep2c20 in smaler fbga 256 package.
as i already have routed in 2 layers ep2c20f256 device then i will need to add ground planes and vcc int,i/o plane.
how much layers these small fpgas need 4 or 6 ?
if i will need in future larger device then i will make pcb for fbga672 package becose it covers larger devices than fbga484.
wen i will route mu nev 4 layer or 6 layer pcb the i will post link to pictures.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17265)
--- quote end ---
--- Quote End ---
if you want a cheap board have a look at:
http://www.jopdesign.com/cyclone/index.jsp (http://www.jopdesign.com/cyclone/index.jsp)
I locked at your link stonie and there is bords with ep1c12 device (old cyclone I ) but I need bord with cyclone II device and at least ep2c20 becose it hase 4 PLL and 16 clock inputs like oll bigger cyclone series devices and also need bord with acces to all pins for experimenting and that I don&#39;t like in all development bords that there isn&#39;t acces to all pins.
my bord for EP2C20F256 (with only 152 I/O) will have 200 pins availible and there will be all pins include VCC IO for all I/O banks and all special function pins and onbord will be this configuration memory (16mb) and power supply for core and memory IO bank and one oscillator and JTAG.
All ather interfaces I will put on ather bord (for example cheap 2 layer) and then will stick bords together (so my bord will be like module http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Actualy I found Cheapest FPGA development bord for 175$ with lot of features on it!, but it isn&#39;t ALTERA it is LAttice and it have powerfule FPGA device which can be compared to ep2c20F484 but disadvantage is this device prise it is more expensiver 72$ than cyclone device 42$ so I will not buy this bord becose I alrady explores Quartus software and don&#39;t want to spend time lerning ather sofware. BUT ALTERA and ather bord developers can lern from them
HOW tom MAKE extremy CHEAP development bord from begginers !!! Becose bord with price 1000$ scare begginers like me!
are you looking to make this board just for fun, or for commercial purposes?
Now I don&#39;t have company So I am making for my self and freand but if we will develop some realy good product like CNC motion controller then i could make company and all ather bords then will be for comarcial pourpouse like part of system.
It all depends on how successful we will be in code developing and how fast I will learn use all features that FPGA offers.
FPGAs is bigg challenge for me! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
--- Quote Start ---
originally posted by jdhar+jul 31 2006, 06:33 pm--><div class='quotetop'>quote (jdhar @ jul 31 2006, 06:33 pm)</div>
--- quote start ---
my god, 14 layers is way too much... you can get a 256bga on a 6-layer, 4-layer if you don&#39;t hav etoo much high speed stuff.[/b]
--- quote end ---
no jdhar. it is definitly not from a point of view of emc purpose.
for a 484 bga you will need up to 5 layers for fanout purposes.
you will need 1 powerplane for vio 3v3 and 1 for vcore 1v2.
both powerplanes need to be seperated by one gnd plane
each routing layer needs a gnd plane where the e and h field go to.
so if you draw such a layerstack :
1 top
2 gnd
3 vcore-plane
4 gnd
5 vio-plane
6 gnd
7 routinglayer 1
8 routinglayer 2
9 gnd
10 routinglayer 3
11 routinglayer 4
12 gnd
13 bot
this 13 layers so 1 layer left for other purposes.
be aware of that the distance between the core and gnd is 50um and between routinglayer as far away as possible.
<!--quotebegin-jdhar@Jul 31 2006, 06:33 PM
484 can get on a 6-layer very easily. i have put a 672 on an 8-layer, but it could have been dropped to 6 possibly.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17294)
--- quote end ---
--- Quote End ---
i do not see a solution of a 484 with 6 layers. 3 layers are needed at least for a power supply that is wide decoupled for signals of several hunderd MHz. to reach the inner balls of the 484 of a cyclone 2 you need 5 layers even with 4/4mil. so 8 layers would be the minimum.
the question is if the pcb has to be an industrial design that can stand all approval test like burst surge TEM ..... and furthermore pass the etsi requirements if the design needs to pass.
a propper powerplane design is needed if you have a clock speed of 50MHz (sinus!!) you will end up with the 5th that ist 5x50MHz meaning at least 250MHz to get a proper recangle. so your design must handle 250MHz wide low impedance powerplane. this can only be archieved with a full copper plane for gnd and for each supply with a distance of 50um. 100um woulod work but you lose the profits of the field effects that occur between the planes!
to have a propper signal on you pcb (again 50MHz clock leadts to at least 250MHz) you need to have an eye on impedance and crosstalk between layers and traces.
with a layerstack as mentioned above the board has a optimum signal, nearly no emission, reaches class A of emc tests and does not "recognise" any burst or surge pulse. even the TEM does not have any effect.
with less layers it is possible to disturb the same design and a couple of peaks will rise during the tests between 30 and 1000 MHz.
i have seen the emc tests of "eval kits" with as less as possible layers and these pcb will never pass the emc requirements !! not only the peaks are far above the limit line.
again the question is for what purpose the design should be.
if the design is pure digital then it could work, but if there are analog parts within the complete design where you want to find signals within the noise a bad power supply will destroy everything. we had a barcode reader design where just modifying the powersupply lead to 18% more readings leading to a better product.
an rfid reader got 30% more reading distance by just modifiying the layout
without changing any component or the placement (to use the paste masks again after the design change.
Michael Schmitt
I think 6 layers for BGA 256 would be maximum and I will tray to make some space for EMI filters (like chip ferrite beads).
Now I add power supply circruit and making DEsign compression.
--- Quote Start ---
originally posted by epis@Aug 2 2006, 12:49 PM
here are some pictures (links to them)
all pcb picture in freepcb software http://theonlyway.net/eoz/upload/attachmen...35&d=1154516195 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=735&d=1154516195
1. top layer in viewmate gerber file viewer with ground plane
http://theonlyway.net/eoz/upload/attachmen...39&d=1154517429 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=739&d=1154517429
2. inner 1 layer with vcc int plane
http://theonlyway.net/eoz/upload/attachmen...36&d=1154517013 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=736&d=1154517013
3. inner 2 large ground plane
http://theonlyway.net/eoz/upload/attachmen...37&d=1154517013 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=737&d=1154517013
4. bottom layer combine vcc io with gnd and vcc int for few capacitor placement
http://theonlyway.net/eoz/upload/attachmen...38&d=1154517013 (http://theonlyway.net/eoz/upload/attachment.php?attachmentid=738&d=1154517013)
now i will serch place for power supply and ather components !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17352)
--- quote end ---
--- Quote End ---
How do you plan to solder the BGA package ?
I contacted sevral companys but there is only one company (in my contry) who could solder BGA and test with x-Ray, but they are asking 400-700euros (for Quantities 1-100 and in local forum gays sayed that in mobile phone repair servic they solder these BGA packages for mobile phones so maby they will solder few FPGAs for 20$ http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif if not then there is alternative it is (Home) electrical owen were could be solderes SMD parts. There are few links were is described how to do this soldering in home http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif and after soldering I will make testing.
Is there some cheap companys that can make PCB and asemble it ??
i found good desciption about FPGA ground design in xilinx page and they have example of how to chose capacitors and they Quantity and I recalculated for my ep2c20f256 and here are results i got :
For VCC INT 1.2V (VCC int has 9 pins and VCC IO 20 pins = 29 VCC pins)
680uF Q=1
2.2uF Q=4 0805
0.47uF Q=8 0603
0.047 Q=16 0402
totaly there is 29 caps for each voltage level so I will doble number off all caps for 2 voltage levels and will have 58 caps.
Once again I am thinking that it would be mutch esear to buy this cheap FPGA bor for 175$ but in future If I will develop some good application I will have to designe this PCB anyway, and will have to buy expensive Lattice Fpga 72$ is olmost twice as mutch comared to ep2cC20 42$
I will redesigne my PCB http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif becose there is too litle place for cap vias and only way is use 6 layers insted of 4.
Has anyone used POL power-off-load power supply tehnology????
I found bellnix BSV ultra fast series with switching freqency up to 3Mhz with low voltage ripple 40 mV and it needs only 2 22uF ceramic capacitors and few higher freqency caps and no inductor!
Also I found 4Mhz power supply it is Ltc3414 (linear tehnology) !
I read about these high frequency switch power supplys and they are specialy recomended for FPGAs.
Hi Epis,
the LT3412A ist feeding my ep2c50 with Vcore 1,2V from 3,3V and works perfect.
But you need to take care about the layout or the ltc34xx family will oszilate and won&#39;t produce a stabel vcore. we have verified that on 2 different pcb&#39;s with different placement and both do not work identical as the placement and layout is different. but it is a good family from linear. the ltc3412a can deliver up to 2,5A and the one you mentioned can deliver up to 4A.
The switching frequency depends on the design. the parts, the input and output voltage and currents. the ltc3412a we use can also switch up to 4 MHz but it runs here at abot 1.5MHz.
Michael
