공지
My multiprocessor test design.
명예로운 기여자 II
1,086 조회수
hi,
I spent more than 1 month to implement a multiprocessor system. It is
made of two niosII cpu core and a modified uc/osII rtos is added to
surport it.
I'd like to share my experience here. This is the key point:
Hardware:
1.To identify each cpu,I implement a custom instruction to set and
read cpu id(it may support now),which are useful in operation system.
2.Since there is no atomic read-set instruction support in niosII.To
synchronize cpus,I implemented a user define spin-lock device.When cpus
read it,It return 1 to inform the cpu the it successfully locked,or
return 0 for failed. Then,cpus write the device to unlock.the device
contain 16 spin-locks,which are enough to OS to protect critical section.
It can aslo be used to atomicly read-set a memory location. So mutex
are easy to implement too.The total mount of mutexes used by
application(on us/os) are not limited.
3.Sending interrupt between cpus is needed to communicate between
cpus,for example, used by os to schedule tasks.To send interrupt between
cpus,I design a ipi(inter processor interrupt) device which has more than
one slave port, each port are connect to a single cpu with a same irq
number.Each cpu can access the device to send irq and associated data to
others.The irq and data are use to communicate between cpus.I used them
for task schedule only.
Software:
I modified the uc/os source code to support the smp architecture,
include the schedule part,context switch part and so on.To support niosII
with data cache, data cache flush are added in some part of the os core
to manage the cache coherence in software way.
Result:
I write a parallel application to test the system.
Both cpu work very FINE when data cache of the two cpu(niosII/s) are
not used.The speed is about two times than that of one cpu,if there is
not so many shared data.(it depends on the application) They run very
steady, and I believe more cpus are possible to add into it,although more
I/O collision will happen.
But,it sometimes crashed when cpu data cache (niosII/f) are used.
I have been seeking the error for a long time, but I have not found the
reason.I put alt_flush_dcache_all() every location where it may be
needed,but it still run error sometimes. I am now a little upset.
I design the system just for a homework, Since I am a newbie in fpga
field,I don't know how to evaluate the design. Is there some problems?
I'd like to know your comment.
btw: what does the arbitration priorty in sopc builder mean? why can't I
change them from 1 to 2?
0 포인트
0 응답
응답
