NET SNMP compile errors
i wanted to add snmp to my nios2linux .
when i following the http://www.nioswiki.com/operatingsystems/uclinux/netsnmp
some errors:
checking for AIX... no
checking build system type... Invalid configuration `i686-pc-linux-uclibc': machine `i686-pc-linux' not recognized
configure: error: /bin/sh ../config.sub i686-pc-linux-uclibc failed
make[3]: *** [build/Makefile] Error 1
make[3]: Leaving directory `/nios2linux-vu1/uClinux-dist/user/net-snmp'
make[2]: *** [net-snmp] Error 2
make[2]: Leaving directory `/nios2linux-vu1/uClinux-dist/user'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/nios2linux-vu1/uClinux-dist/user'
make: *** [subdirs] Error 1
You have new mail in /var/spool/mail/root
[root@localhost uClinux-dist]#
somebody said :
edit config.sub:
add "| nios2" in the "case $basic_machine in"
run:
./configure --host=nios2-linux --with-cc=nios2-linux-gcc --disable-shared -enable-static --with-endianness=little
compile and seems to work fine. (works under linux not cygwin)
but still have the same errors .
who can tell me how to do ?
thanks.
