I'm trying to setup an NFS share on the 1c12 dev board. I add into kernel : <div class='quotetop'>QUOTE </div> --- Quote Start --- File system --> Network FS --> [*] NFS file system support [*] provide NFSV3 client support [*] NFS server support [*] provide NFSV3 server support [*] provide NFS server over IP[/b] --- Quote End --- I want a network share named flashfs which is a /flashfs directory.# mount -t nfs 172.16.207.43:/flashfs /flashfs -n -o nolock I've got the error <div class='quotetop'>QUOTE </div> --- Quote Start --- mount: RPC: Port mapper failure - RPC: Unable to receive[/b] --- Quote End --- In case I built uClinux portmap but when executing I've got the error <div class='quotetop'>QUOTE </div> --- Quote Start --- portmap: fork: Function not implemented[/b] --- Quote End --- What am I missing? Please help Thks MarcLink Copied
NFS server support
mount -t nfs 218.192.171.46:/home/nfs /usr/bin -n -o nolock
/home/nfs is a dir which your host linux should share it by NFS server. /usr/bin is the mount point for Nios2 target to access
Thank you very much for your help
Marc
