12748 Discussions
NIOS IDE and makefile problems kill me.
hi :)
sorry for my poor eng.
I'm kor. student and trying to compile h.264 decoder (jm86.zip) for NIOS II, using NIOS IDE tool but I faced big fat desperate problem.
I have makefile( for.. might be for i386??) and all the source code and *.h files, but I cannot compile it for NIOS II by using NIOS IDE!!!
you know I have to compile the source files via NIOS IDE to make it work.
So... anyone have any idea??
how can I open the makefile(I aleady have)?
how can I cross-compile it?
I have makefile like this.
#### ##     Makefile for H.26L encoder# ### ##             generated for UNIX/LINUX environments# ##             by H. Schwarz# ## NAME=   ldecod # ## include debug information: 1=yes, 0=no# DBG= 0 DEPEND= dependencies BINDIR= ../bin INCDIR= inc SRCDIR= src OBJDIR= obj ADDSRCDIR= ../lcommon/src ADDINCDIR= ../lcommon/inc CC=     $(shell which gcc) LIBS=   -lm FLAGS=  -ffloat-store -Wall -I$(INCDIR) -I$(ADDINCDIR) ifdef DBG SUFFIX= .dbg FLAGS+= -g else SUFFIX= FLAGS+= -O2 endif OBJSUF= .o$(SUFFIX) SRC=    $(wildcard $(SRCDIR)/*.c) ADDSRC= $(wildcard $(ADDSRCDIR)/*.c) OBJ=    $(SRC:$(SRCDIR)/%.c=$(OBJDIR)/%.o$(SUFFIX)) $(ADDSRC:$(ADDSRCDIR)/%.c=$(OBJDIR)/%.o$(SUFFIX)) BIN=    $(BINDIR)/$(NAME)$(SUFFIX).exe default: depend bin tags dependencies:     @echo "" >dependencies clean:     @echo remove all objects     @rm -f $(OBJDIR)/* tags:     @echo update tag table     @ctags inc/*.h src/*.c bin:    $(OBJ)     @echo     @echo &#39;creating binary "$(BIN)"&#39;     @$(CC) -o $(BIN) $(OBJ) $(LIBS)     @echo &#39;... done&#39;     @echo depend:     @echo     @echo &#39;checking dependencies&#39;     @$(SHELL) -ec &#39;$(CC) -MM $(CFLAGS) -I$(INCDIR) -I$(ADDINCDIR) $(SRC) $(ADDSRC)                           | sed &#39;\&#39;&#39;s@\(.*\)\.o@$(OBJDIR)/\1.o$(SUFFIX):@g&#39;\&#39;&#39;                       >$(DEPEND)&#39;     @echo $(OBJDIR)/%.o$(SUFFIX): $(SRCDIR)/%.c     @echo &#39;compiling object file "$@" ...&#39;     @$(CC) -c -o $@ $(FLAGS) $< $(OBJDIR)/%.o$(SUFFIX): $(ADDSRCDIR)/%.c     @echo &#39;compiling object file "$@" ...&#39;     @$(CC) -c -o $@ $(FLAGS) $< include $(DEPEND)
and I have all the source files.
http://ftp3.itu.ch/av-arch/jvt-site/ (http://ftp3.itu.ch/av-arch/jvt-site/
here.
reference_software/jm86.zip
plz help me save me
I&#39;m about to die... :(
your program need os support.
you may try uClinux.
http://nioswiki.jot.com/%c2%b5clinux (http://nioswiki.jot.com/%c2%b5clinux
it is easy to run makefile.
CC = nios2-linux-uclibc-gcc
unzip -a jm86.zip
but your codes are not clean for gcc.
it seems they are for vc. (bad coding style).
global are mixed up in global.h , they should be extern .
