NIOS II EPCS bootloader
I have a Cyclone III and am trying to use EPCS to boot my NIOS II code. I can flash the device with the NIOS Flash Programmer without error but removing the JTAG header and cycling power doesn't appear to start my code. The Verilog code appears to be running. I've configured the NIOS reset vector to point to the EPCS flash controllers address. I've configured the syslib linker section as follows:
Program memory: sdram
Read-only data memory: onchip_memory
Read/Write data memory onchip_memory
Heap memory: onchip_memory
Stack memory: onchip_memory
The syslib RTOS settings is set to "none (single-threaded)"
Any debugging tips would be greatly appreciated!
Jim
Look at the final post of this topic (http://alteraforum.com/forum/showthread.php?t=5547) on Altera Forum and try the workaround that it mentions.
Cheers,
- slacker
Thanks Slacker!
I'm trying it now. Its always nice to find these "undocumented features" in software you paid money for!
Jim
Is this fixed in Quartus 9 SP2 ?
