I am using NIOS II 7.1 SP1 IDE, I have been seeing this issue intermittently but today nothing will work and I can not use IDE to debug my software anymore :(.
When I go to debug the code, the it downloads and verifies correctly into SRAM but then I get the following message when I tries to start he processor. Execution is suspended because of error Warning: Cannot insert breakpoint 1. Error accessing memory address 0x580cbe0: Unknown error 4294967295. I saw the same message last Friday but it was intermittent and I thought maybe I had damaged the board so I went to a known good board. I worked all week with the new board and everything was fine yesterday. I made minor changes to my NIOS code and the problem was intermittent. I came in this morning and the problem happens every time. I reverted back to known good code that worked earlier in the week but the problem persists. Out of desperation I rebooted my computer but that didn't help. The board works fine when I download the code to flash and reboot (versus using IDE) and the sram passes diagnostics when the diagnostic image is loaded so I don’t believe there is a hardware problem. I just can’t get the IDE to work? Could you point me in the right direction on how to root cause? thanks, JenniferLink Copied
Hi,I use quartus9.0 and nios 9.0,and met the same problems with you!
