12747 Discussions
NIOS II console is not printing after adding QSPI IP in qsys
MMuth8
In the woking ethernet example, i have added Altera QUAD SPI controller IP (N25Q512A83GSF40F), after adding this IP NIOS console window is not printing. Is there any eclipse settings specific to QSPI IP?
Mahalakshmi
Isaac_V_Intel
Hello Mahalakshmi,
Can you please make sure that the Makefile is been created correctly and up to date?
you can do the following to make sure the Makefileis up to date:
1- Open the BSP project folder
2- Right click the Makefile>> Delete
3- Open the NIOS II Command Shill
4- Write the following command:
cd <...../project_bsp>
nios2-bsp-generate-files --settings=settings.bsp --bsp-dir=<C:/…./<project_bsp/>
5- Build your project again.
Let me know if it works.
Isaac.
Isaac_V_Intel
Hello Mahalakshmi,
Did the solution work?
Isaac.
MMuth8
Hi Issac,
Thanks for your reply.
The solution did not work, still facing the same problem.
Mahalakshmi
Isaac_V_Intel
ok, can you share your design with us? And I could do some debugging.
You are connecting all the clock and reset lines on your NIOS design?
Best regards.
