12748 Discussions
NIOS2 gcc c++ standard library
Hi there,
i am using Quartus 16.1 with gcc version 5.3. If i want to compile a simple project with c++ standard libraries, i'll get a linker error that the memory size is about 615000Bytes too small. That happens with also with all others STL containers. Has anyone else this problem or had anyone similar issues?
I dont know what other information i can give you to explain why this happens, but no clue. I made a BSP, compiled it (no errors) and made a new NIOS Application and tried to use std::string -> error. If i make a C++ Application without strings everything is fine.
Any help would be greatly appreciated, thanks. If maybe more info is needed say so :)
Thanks!
Edit:
main.cpp looks like this:
#include <string> using namespace std; int main() { string s = "Hello World!"; return 0; }
Edit2:
Maybe I should ask differently: Has anybody experience with developing software for the NIOS II target in C++ and has used some of the STL containers / strings? And maybe knows if there were some special settings that had to be made?
