12748 Discussions
Need help about flash programmer
I'm using QuartusII4.2+sp1,NiosII1.1,ByteBlasterII cable, and an EP1C12F324 on my custom board.
I built a flash programmer design as the "NiosII Flash Programmer user guide" instructs(I use a flash and an EPCS4), then I build my system with this board.
After every thing is done, I launch the flash programmer and want to program the software and the hardware image into epcs, it tells me that "Unrecognized EPCS device ID: -1". I'm sure that the EPCS and FPGA is OK, 'cause it can config my FPGA when I program the .pof into it.
What's wrong with my EPCS??
The following is the message from the Flash programmer:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
#! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd H:/Year2005/February/Feb21/System_case7/Test_case04/software/System_case7_tes
t_case04_soft2/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --flash=U4 --offset=0x00000000 --epcs --input=H:/Y
ear2005/February/Feb21/System_case7/Test_case04/Test_case04.sof --output=Test_ca
se04.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS16 --option=Test_c
ase04.opt H:/Year2005/February/Feb21/System_case7/Test_case04/Test_case04.sof Te
st_case04.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Processing ended: Wed Jun 08 18:01:31 2005
    Info: Elapsed time: 00:00:01
Info: Command: quartus_cpf --no_banner --convert Test_case04.pof Test_case04.rpd
    Info: Processing ended: Wed Jun 08 18:01:32 2005
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=Test_case04.flash --sof=h:/Ye
ar2005/February/Feb21/System_case7/USB_Buf_Ver01/system/USB_Buf_Ver01.sof --epcs
Jun 8, 2005 6:01:33 PM - (??) nios2-flash-programmer: Launching Quartus Programm
er to download:
  h:/Year2005/February/Feb21/System_case7/USB_Buf_Ver01/system/USB_Buf_Ver01.
sof
Jun 8, 2005 6:01:52 PM - (??) nios2-flash-programmer: Error opening target hardw
are
Jun 8, 2005 6:01:52 PM - (??) nios2-flash-programmer:    Unable to open flash-de
vice after successfully communicating
with target.
It is likely that you are using a flash-programming FPGA design which
was not created for your target board.
  In order to program flash, you must first create a purpose-built
  flash-programming design (i.e. FPGA configuration) and associate it with
  your particular board.  The Nios development kit is delivered with purpose-bui
lt
  flash-programming designs pre-built for several development boards.  If you wi
sh
  to program flash on your own board, you must first create a flash-programming
  design.
  The process of creating a flash-programming design for your board is mostly
  automated.  From a bash-shell, execute this script:
        mk_target_board --help
  The help-message includes references to other documentation on programming
  flash and targeting Nios systems to custom board designs.
- exiting.
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U9 --base=0x00400000 --end=0x800000 --rese
t=0x1000 --input=System_case7_test_case04_soft2.elf --output=cfi_flash_0.flash -
-boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=cfi_flash_0.flash --sof=__NO_
SOF_PLEASE__ --base=0x00400000
Jun 8, 2005 6:01:52 PM - (??) nios2-flash-programmer: Input file empty--no data
to program into flash. Exiting.
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U4 --epcs --base=0x0 --end=0x7fffffff --in
put=System_case7_test_case04_soft2.elf --output=epcs_controller.flash --boot=$SO
PC_KIT_NIOS2/components/altera_nios2/boot_loader_epcs.srec
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=epcs_controller.flash --sof=_
_NO_SOF_PLEASE__ --epcs
Jun 8, 2005 6:01:53 PM - (??) nios2-flash-programmer: SOF-download skipped.
Unrecognized EPCS device ID: -1Jun 8, 2005 6:02:01 PM - (??) nios2-flash-program
mer: Error opening target hardware
Jun 8, 2005 6:02:01 PM - (??) nios2-flash-programmer:    Unable to open flash-de
with target.
lt
sh
  design.
- exiting.
WARNING: Default charset GBK not supported, using ISO-8859-1 instead[/b]
--- Quote End ---
RM,
The "-1" return value means that the design cannot read the EPCS&#39;s silicon ID.
Does the memtest software example (for EPCS) pass? If so, then you need to double check the command line used for &#39;mk_target_board&#39;, as the problem is likely with the SOF that this procedure created.
Also, if at all possible, I&#39;d recommend updating/upgrading to Quartus II/Nios II 5.0.
Cheers,
- slacker
I solved this problem.
Originaly, in the mk_target_board design, I changed the asmi component into the epcs_controller,
&#39;cause in NiosII the epcs_controller supersede the asmi component. Maybe I did not change the
base address of epcs_controller to the asmi&#39;s, or something else. Then I kept the asmi component
and did not use the epcs_controller.
When I fixed this bug, new problem emerged. The flash programmer told me that it cannot synchonize with the target device.
In previous posts, someone has mentioned that increasing the clk frequency may solve this problem. Then I upgrade the clk
from 48M to 80M, then it works.
Thank u.
Which flash are you using ?. Did you only change the PLL on your flash programmer target board, or did you change it also in the SOPC builder clock frequency ?.
