12745 Discussions
'New Nios II Application and BSP from template' Freezing and Unresponsiveness in Eclipse
admaris
I have created a Nios II Qsys project in Quartus Std 23.1, and I'm encountering two different issues with Eclipse. 1. When I try to use 'New Nios II Application and BSP from template,' there is no response at all. The action seems to have no effect. 2. On rare occasions, when I do get the 'New Nios II Application and BSP from template' wizard to open and move to the next step, after selecting the .sopcinfo file from my project, the interface freezes and does not proceed further. Could you please help identify the potential causes of these issues and suggest a solution?
admaris
Detailed Information from .log File
BoonBengT_Altera
Hi @admaris,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Just a note, unfortunately for Nios II product it has been deprecated and would advise to move NiosV instead. More details can be found in the link below:
- https://www.intel.com/content/www/us/en/content-details/781327/intel-is-discontinuing-ip-ordering-codes-listed-in-pdn2312-for-nios-ii-ip.html?DocID=781327
However we would still try our best to get into the challenges you mention on NiosII.
The error seems to be complaining about some GTK error, perhaps try to check the GTK version on your host by running the command gtk-launch --version.
And try to enable GTK2 instead by editing your Eclipse launch script (e.g., eclipse.ini) and add:
--launcher.GTK_version
2
Hope that clarify
Best Wishes
BB
JingyangTeh_Altera
Hi
Do you have any more follow up question on this case?
Jingyang, Teh
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
