Newbie help
I tried to run hello.c as per the tutorial in the linux reference guide. However, I get the following errors when i build the project (in the Nios IDE - Im using Nios2 eval kit 1.1) :
Description        Resource           In Folder        Location *** No rule to make target `../Rules.mak'.                        hello_world   *** No rule to make target `hello.exe', needed by `all'.   hello_world     ../Rules.mak: No such file or directory                                Makefile           hello_world      line 3
I used the same makefile given in the folder with the hello.c program and did not edit the Rules.mak
The code for the rules.mak:
TOPDIR = .. include $(TOPDIR)/Rules.mak # # configurable options#  - set DEBUG = 1 to turn on debugging support# DEBUG = 0 PROJ_NAME = hello INSTALL_DIR = PROGS := $(PROJ_NAME).exe CFLAGS += # # You should not need to modify anything beyond this point# ifeq '$(DEBUG)' '1'     CFLAGS += -O0 -g     PROGS += $(PROGS:.exe=.gdb) endif all: $(PROGS) .PHONY: clean clean:     -rm -f *. *.elf *.gdb *.bin *.exe .PHONY: install install: all ifeq "$(INSTALL_DIR)" ""     $(error No installation directory specified) endif     mkdir -p $(INSTALL_DIR)/bin     install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
The code for the rules.mak:[/b]
--- Quote End ---
I think that you meant Makefile because this is the code of the makefile.
I think that the problem is :
--- Quote Start ---
TOPDIR = ..[/b]
--- Quote End ---
That means that the path of your Rules.mak file is one directory above the project&#39;s directory.
If the Rules.mak and Makefile are in the same directory then you must change the TOPDIR to :
TOPDIR = ./
Yes, you are right. It worked after changing it.
Thanks for the help.
