12748 Discussions
Nios II 6.0 -- gcc source code
I finally received my 6.0 CDs, but I didn't see the gcc source tarball
on the Linux CD. The sources were in common/gnusrc.tgz in v5.1.
Does anyone know where the sources are?
--Scott
Hi Scott,
I can find the source tar file in nios2 linux full 6.0 beta.
But I didn't get the final release yet.
The nios2 comes with quartusII 6.0 is evalutaion edition, there is no gnu sources.
Do you have nios2 full edition?
Hippo
Hi hippo,
Ok. Understood.
I have a full license ... but I haven't received the 6.0 Nios II CDs yet, only Quartus.
BTW: With v5.1 I also noticed that the sources on the linux CD and the sources on th eWindoze CD
are _not_ the same. (unless I fat fingered something along the way ... which is possible).
Anyway, thanks for the info :-)
--Scott
Hi Hippo,
A few more questions:
What version of binutils and gcc is used in 6.0?
Did you hear anything about the release date? ... other than 'soon' ;-)
--Scott
--- Quote Start ---
originally posted by smcnutt@May 26 2006, 09:12 PM
hi hippo,
a few more questions:
what version of binutils and gcc is used in 6.0?
did you hear anything about the release date? ... other than 'soon' ;-)
thanks,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=15603)
--- quote end ---
--- Quote End ---
They are binutils 2.15 and gcc 3.4.1, the same as before.
They added some new features to gcc, you can find them in the gnutools doc.
I had asked about the release, but didn&#39;t get an answer too.
Scott,
The 6.0 GNU tools sources are at the same FTP location that the previous ones could be found:
ftp://ftp.altera.com/outgoing/download/su...sors/nios2/gnu/ (ftp://ftp.altera.com/outgoing/download/support/ip/processors/nios2/gnu/
There&#39;s a website that needs updating, which probably caused this confusion:
http://www.altera.com/support/ip/processor...e-tutorial.html (http://www.altera.com/support/ip/processors/nios2/ide/ips-nios2-ide-tutorial.html
Hope this helps....
Cheers,
- slacker
slacker & hippo,
As always, thanks for the help :-)
--Scott
The tarballs don&#39;t have the newlib sources -- are we still at version 1.12.0 ?
--Scott
