12748 Discussions
Nios II Embedded Design Suite and Processor
could someode tell me why i could need the Nios II Embedded Design Suite for ein Video application, and what about Nios II Embedded Processor?
Nios has "memory mapped" and "streaming based" processing blocks and interconnect.
So basically you get a proven system that works, and you can concentrate on adding the extra features you want, because the rest will just work from day 1.
if you are using VIP Suite, the blocks can have run-time control of parameters. these parameters are controlled over an Avalon-MemoryMapped bus. you can write an HDL state machine to load the registers over Avalon-MM, or you could use a Nios II processor.
--- Quote Start ---
--- Quote End ---
I am new with the Nios II processor. I intend to use it to implement it in a SOPC . It's for a controller in power electronic applications. I would like to know why the Nios II could be a good option over other soft-cores for power electronics ?
