For those people looking for the Evaluation version of the Nios II IDE v1.1, it can be downloaded here:
download nios ii evaluation tools 1.1 (https://www.altera.com/support/software/download/nios2/dnl-nios2.jsp?f=ni2ide&k=g1) More information regarding device support, licensing and system requirements can also be found on that web page.Link Copied
but i don't see in supported devices list EPCS16 support ... on link below
http://www.altera.com/support/ip/processor...vkit1.1-rn.html (http://www.altera.com/support/ip/processors/nios2/ips-nios2_devkit1.1-rn.html) Is it supported in that version ? Because in altera site is writen next http://www.altera.com/products/software/pr...html#flash_prog (http://www.altera.com/products/software/products/nios2/emb-nios2_ide.html#flash_prog) _________________________________ Flash Programmer !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! In addition to CFI flash, the Nios II IDE flash programmer can program any Altera serial configuration device connected to the FPGA. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ________________________________ ANY ALTERA CONFIGURATION DEVICE So how about EPCS16? Can you check that ?- Mark as New
Is there any information about what's new/different in the 1.1 release, and what the compatibility issues are?
In particular, is uCos-II/LWIP still supported under V1.1? - Roddy- Mark as New
Hi all,
I m beginner student , i want to know how to desing with quartus or nios IDE and which is better ? my apllication is partioned between HW and SW!!! thanxxx in advance- Mark as New
Hi Beymaz,
it's a long argument... I think u can download some documents from altera site... In general, Quartus is used to design HDL blocks, and it's hardware design;SOPC builder is linked to it, it allows you to create HDL blocks containing Nios processor;IDE is linked to it, it allows you to create software project for Nios II processor...- Mark as New
Hi soin,
thanxx for thos informations. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif- Mark as New
Hi everyone.
I have read that the free software doesn't permit the simulation. Is it true?- Mark as New
The free license (called web license) doesn't allow the use of the ModelSim Altera software - this means you won't be able to use the Nios testbench generated by SOPC Builder, but you can do small simulations in the Quartus' built-in simulator. Also you can go to www.model.com (http://www.mentor.com) and ask for an evaluation license for ModelSim (though will be limited to a month or so probably).
thanks for the answer!
i'd like to know if with Quartus' built-in simulator i can simulate the niosII software? In the altera web site i have read that the altera company provides a ModelSim-Altera software. Is it different from ModelSim that i can donwload from www.model.com? which application notes do you suggest me ? thanks- Subscribe to RSS Feed
