program run error!
when I run a program (hello_world.c)in niosII IDE, some errors occured .what's wrong?
Error! : Unable to load memory block at address 0x800020 from ELF file Debug/hello_world_4.elf
Fatal Error! : Memory map is not consistent with memory image file - check that file 'Debug/hello_world_4.elf' is compiled and linked for system 'D:\test\lab5\my_cpu.ptf'
Hi,skybird.
what hardware image did you use?your own or the example.
If is your own ,did you generate it successfully in sopc builder?
I think the problem is address .
The above is just personnel viewpoint.
Hi,zzh! Thank you for your answer!
The development board I used is Stratix GX ep1s40f1020c5. The nios system which is my own can generate successfully in sopc builder .
Hi skybird,
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Fatal Error! : Memory map is not consistent with memory image file - check that file &#39;Debug/hello_world_4.elf&#39; is compiled and linked for system &#39;D:\test\lab5\my_cpu.ptf&#39;[/b]
--- Quote End ---
from this message, I think that your software project it&#39;s not correctly linked with your hardware configuration: I mean, when u have created your project have you specified the file "my_cpu.ptf" and created an associated system library?...or have u downloaded the correct hardware configuration to FPGA, before downloading software project?
bye
