Nios II IDE program usage
Using Nios II IDE, how can I re-display the "Build" results after it is completed?
The results just show for a while in the console then disappear!
click on the fourth button (from the rigth) on the console tab to switch from one console to the other...
So in which console can I find the build results ?
In the C-Build console, click on the "v" of that button to list al the available consoles...
okay .. the problem is that the Nios II IDE build the project in separate stages and I cannot view the previous stages report, but only the last one. So i need a way to see all of the reports generated while building.
