***Read Me First***
*** please only post questions about c2h in this section of the forum ***
Here is a collection of material that you can take a look at to learn more about the Nios II C-to-Hardware compiler.
c2h user guide
http://www.altera.com/literature/ug/ug_nios2_c2h_compiler.pdf
http://www.altera.com/literature/ug/dma_c2h_tutorial.c
c2h power reduction
http://www.altera.com/literature/an/an531.pdf
http://www.altera.com/literature/an/power.zip
reducing power using hardware acceleration whitepaper
http://www.altera.com/literature/wp/wp-01112-hw-reduce-power.pdf
c2h tutorial
http://www.altera.com/literature/tt/tt_nios2_c2h_accelerating_tutorial.pdf
http://www.altera.com/literature/tt/c2h_tutorial.zip
c2h appnote (sgdma with checksum)
http://www.altera.com/literature/an/an417.pdf
http://www.altera.com/literature/an/an417_checksum_design_files.zip
c2h whitepaper
http://www.altera.com/literature/wp/wp-aghrdwr.pdf
c2h optimization guide
http://www.altera.com/literature/hb/nios2/edh_ed51005.pdf
http://www.altera.com/literature/hb/nios2/edh_c2h_optimization_design_files.zip
c2h design examples
http://www.altera.com/support/examples/nios2/exm-c2h-mandelbrot.html
http://www.altera.com/support/examples/nios2/exm-c2h-image-rotate.html
http://www.altera.com/support/examples/nios2/exm-c2h-fir.html
Starting in 11.0 C2H is an optional install feature. In order to have C2H support installed you must install the Nios II Legacy tools. Also C2H is only supported in the Nios II IDE and not the software build tools for Eclipse software development environment.
