12746 Discussions
Nios II Software Build Tools for Eclipse - c99 mode
Hi every one!
I'm using Quartus 11.0 sp1 and Nios II Software Build Tools for Eclipse with DE2-70 Altera board.
How can I configure "mingw nios ii gcc4" in eclipse to use the c99 mode? (I have other toolchains available in addition to MinGW NIOS II GCC4)
I searched the web for this topic and I found results for "Eclipse CDT". The solution is to modify the flags under:
Project Properties > C/C++ Build > Settings > GCC C Compiler > Miscellaneous and add -std=c99
However I didn't find such configurations with the "Nios II Software Build Tools for Eclipse".
I apologize if the question is dumb. I am still a newbie.
I appreciate any help.
Thanks in advance.
Why do you need to explicitly specify -std=c99?
gcc tends to support most of c99 without it.
Specifying -std=c99 also removes some of the gcc builtins - like alloca(), which can only really be implemeted by the compiler.
using the software build tools eclipse gui
Right Click On Project Folder in the Project Explorer
Select Properties
Nios II Application Properties
User Flags: -std=c99
With software build tools sometimes setting -std=c99 in the GUI doesn't seem to stick :mad:. I never figured out why :confused:. What I did to make it stick was to edit the projects MAKEFILE directly by setting the APP_FLAGS_USER_FLAGS to include -std=c99 .
using the makefile (direct method)
search for app_cflags_user_flags
app_cflags_user_flags := -std=c99
legacy nios ii tools
Right Click On Project Folder in the Project Explorer (aka NIOS II C/C++ Projects tab)
Select Properties
Select The C/C++ Build item
Tool Settings Tab
NIOS II Compiler-->General Folder
Compiler Flags: -std=c99
--- Quote Start ---
Select Properties
--- Quote End ---
Yes, setting -std=c99 in the GUI doesn't seem to stick in Q13.1
http://www.altera.com/support/kdb/solutions/rd10132014_789.html
