Nios II/e clone
I wrote a Nios II/e CPU clone in verilog.
It takes between 600 and 800 LEs and executes most of the instructions in 4 cycles.
It comes with an ISS and a trace tool. Verilog simulation are possible under the free "verilator" tool.
I am wondering if Altera would allow me to publish this IP.
What do you think ?
Frederic
--- Quote Start ---
What do you think ?
Frederic
--- Quote End ---
Just a follow-up : I have created an SOPC builder component for Quartus 9.1sp1.
If I activate the "Instruction Custom Master" interface under the Component Editor, the custom SOPC component does not show up under SOPC builder.
Here are the signals declaration in the top level:
// Nios II Custom Master output ncm_cm_reset, output ncm_cm_clk, output ncm_cm_clk_en, output ncm_cm_start, input ncm_cm_done, output ncm_cm_n, output ncm_cm_dataa, output ncm_cm_datab, output ncm_cm_a, output ncm_cm_b, output ncm_cm_c, output ncm_cm_readra, output ncm_cm_readrb, output ncm_cm_writerc, input ncm_cm_result,
Is this a known bug of Quartus 9.1 ? It looks like I will be obliged to declare the interface as a "Conduit".
Frederic
I have added a big endian option in the core.
Is there an easy way to tell GCC to generate big-endian code ?
Frederic
Look at the gcc sources, it might need a recompile.
Howver I'm not sure how well non 32-bit Avalon slaves will work on a BE system.
You are likely to end up in the 'mess' of ppc - where io accesses to on-chip resources all need byteswapping.
