12747 Discussions
Nios Software - Azure Devops Build Pipeline
Nir_Zilkha
Is there a way to build a nios project via build pipeline?
If yes can you please give  a  yaml example (for a simple software project + bsp).
Thank you.
JingyangTeh_Altera
Hi
Unfortunately we do not have a Build pipline for the NiosV project.
However there are example design you could generate from our NiosV document:
https://www.intel.com/content/www/us/en/docs/programmable/726952/23-4/processor-example-design.html
Jingyang, Teh
JingyangTeh_Altera
Hi
Any update on this case?
Jingyang, Teh
JingyangTeh_Altera
Hi
Since there are no feedback for this thread, I shall set this thread to close pending. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you happened to close this thread you might receive a survey. If you think you would rank your support experience less than 4 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang,Teh
