12742 Discussions
Nios V: niosv-download reports "no harts found" on Agilex 5 board
JMX
I am seeking for ideas with the following issues I have on agilex 5.
I want to test a very basic example "hello world" on the board. However, I got a problem on downloading the elf file. My sof file includes a noisv processor and it's successfully download to the board. I can run the command jtagconfig and the following output shows the USB Blaster. The .elf file is generated successfully through the cmake command.
However, when I execute the command niosv-download.exe app.elf --go, the follwing error will be outputted.
My design in Platform Designer is attached.
FawazJ_Altera
Greetings,
This seems to be a reset issue. The Reset Release IP is missing from your platform. You may refer to the Nios V application note: https://www.intel.com/content/www/us/en/docs/programmable/784468/current/an-985-processor-tutorial.html
You can follow the steps in 1.2.1 section (1.2.1.1.2.4. Adding Reset Release Intel® FPGA IP).
Furthermore, you may refer to the design examples available for Agilex 5 development kit:
1- Agilex™ 5 - Hello World on Nios® V/g Processor Design Example
2- altera-fpga/agilex5e-nios-ed: Nios V Processor example designs targeting Altera Agilex 5 Development Kits
Thank you,
Fawaz.
JMX
Hi, I have tried to change my design but still shows this output when I run the command NIosV download. I will have a look at the links you attached, thank you so much for your quick reply!
JMX
And also I have tried the ready-to-test in this link https://github.com/altera-fpga/agilex5e-nios-ed. I download the .sof file to the board through Quartus Prime Pro 25.1 -> Tool -> Programmer -> Change File ->top.sof, then run the command NiosV download, the command shell still shows the error.
FawazJ_Altera
Can you try to reduce the JTAG Speed using the command below:
jtagconfig --setparam 1 JtagClock 6M
After that, download the Nios V elf file:
niosv-download -g -r app.elf
I will test the Github design on board, and I will let you know my findings.
Thank you,
Fawaz.
FawazJ_Altera
We have tested the Github ready-to-test files, and they are working on boards.
I would like to know if you are using a development kit or customer kit. Also, what is your device OPN.
Furthermore, can you program the .sof file, then use Nios V command shell and type the following command:
jtagconfig -n
Send me the output of this command.
Thank you,
Fawaz
BoonBengT_Altera
Hi @JMX,
Good day, just following up on the previous clarification.
By any chances did you managed to look into it?
Hope to hear from you soon.
Best Wishes
BB
