12748 Discussions
Nios V starts in debugging mode, but not in stand-alone mode
KennyJoosen
I have migrated a working Nios II/f instance to a Nios V/g one.
When launching a debugging session with RiscFree IDE and JTAG to this Nios V instance, everything operates as expected. However, when running the image with this Nios V instance, the application does not start (at the start log messages should appear, but those are not visible with the JTAG UART terminal).
I have followed the migration guide, but I am probably missing something. Do you have any pointers for me to look at?
KennyJoosen
I found the cause of the issue: the conversion of the ELF file to HEX file went wrong. I was using elf2flash and riscv32-unknown-elf-objcopy commands, while I should have been using the elf2hex command.
Conversion command used now:
elf2hex ${PROJECT_ELF} -o ${PROJECT_HEX} -b 0x00000000 -e 0x0007ffff -w 32 -r 4
JingyangTeh_Altera
Hi
The uart terminal NiosV command is different compared to NiosII.
Are you using the juart-terminal command for the NiosV uart?
Besides that, have you tried creating a simple hello world in the NiosV?
Jingyang, Teh
KennyJoosen
I am using the juart-terminal command. When launching my application in debug mode with the RiscFree IDE, logging appears on the juart-terminal as expected and the application behaves as expected.
However, the Nios V application doesn't seem to start when being part of the FPGA image and no debugger is attached/launching it, since no logging appears on the juart-terminal (first lines that should be executed in the code) and application seems unresponsive/behaves not-expected (seems to do nothing).
JingyangTeh_Altera
Hi
Which boot method that you are using?
In general there are 3 types, Running OnChip Memory , XIP Flash Memory and boot coopier from Flash memory.
https://cdrdv2-public.intel.com/793065/ug-726952-793065.pdf
Section 4.3
KennyJoosen
JingyangTeh_Altera
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
