Nios2 SDRAM+LAN bus sharing
Hi all!
I have been attempting to use the bus-sharing feature of the SDRAM controller, along with the LAN controller.
The SDRAM seems to be working okay!, but so far no luck with the LAN controller....
Can I ask some of you folks to verify that I have carried out the address bus part-select correctly on my schematic?
http://tinyurl.com/6goor (http://tinyurl.com/6goor
It took me a while to work out how exactly to do this, but I'm assuming that I do not need the full A15..0 because the device driver does not use it all?
Have I broken anything by not supported the full A15..0 address bus?
Thanks!
;O)
Does anybody have any experience with bus-sharing feature of the SDRAM controller?
Thanks!
I've never found a complete write up about the rules for signal names.
I would recomment that you break the verticle bus that connects
ext_ram_bus_address[15..0] and ext_ram_bus_address[11..0]
That connection looks 'wrong' to me.
Keep us posted
I agree with gmm... I would expect Quiartus to give a compilation error becaue of a mis-matched bus width; you are attempting to throw away 4 address lines but Quartus doesn't know that.
You should try this in case you're seeing such a compilation error:
addr ( from SOPCB ) ---- name the bus "my_addr"----x
the 'x' means that you don't connect the line to anything. then, to get to your pin, make a separate named bus wire like this:
  x----name this one "my_addr"--------<<--IO named "my_addr-->>
Then quartus knows explicity that you want to connect 11..0 on your IO to 11..0 on the bus coming from the SOPCB module.
