NiosII SPI Core problem
Hi, all
i use a SPI core in my nios system.
when i used the function "alt_avalon_spi_command()" to sent a "who am i" command to the peripheral, it received no data. so i use signalTap to debug.
here's the data i got
http://ww1.sinaimg.cn/large/4abedc10gw1dk7o6m3q7ej.jpg
my questions:
1)MISO has received the data sent back by peripheral, why rx_holding_reg and shift_reg received nothing?
2)is there anything wrong in my code?
int main() { alt_u8 temp; alt_u8 wdata = 0x80 | WHO_AM_I; if(alt_avalon_spi_command( SPI_L3G4200_BASE,0, 1,&wdata, 1,&temp, 0)==0) printf("fail\n"); else { printf("%d\n",(int)temp); } }
thanks
It's been a long time since I have used that core but I recommend looking at the control and status registers of the SPI core to make sure the TX hasn't overflowed or the RX hasn't underflowed. I forget the behavior but in those two cases the SPI component either stops moving data or it just loops the data back.... or something.... I forget.
TAT... i make it.
when i add a NOT gate at MISO, it works.it seems that Nios cannot catch the signal starts with "1".
Try increasing the delay parameter of the SPI core so that there is a bit of delay between the SS_N deassertion and sclk. One sclk of delay should hopefully do the trick.
Hi everyone!
I'm also using an SPI core to connect my peripheral to nios and I also send "who_am_i" command, but I'm experiencing some difficulties. When I send data using altera_avalon_spi_command(), here are the signals from SignalTap Logic Analyzer (SCLK, SS_n, MOSI, MISO):
https://www.alteraforum.com/forum/attachment.php?attachmentid=5300
My SPI is configured as master, SCLK=10MHz, Data Register width = 8, Clock polarity = 1, Clock phase = 1. I can see that in q3ccn's picture spi clock exists as long as SS_n signal is deasserted which doesn't happen in my case. So, I suppose that in the first clock cycle in my picture, the data (0x8F) is sent over MOSI line, but what happens in the other cycle? Why is there such a big period between these cycles? Is it possible that data is sent again in that second cycle or the received data is sampled from the MISO line?
When I configure MISO pin as an input pin in quartus, should I enable pull-up resistor or it is not necessary?
Thanks for any help.
